New guy with a question or 5
Vancouver, WA
I've been lurking and searching here for quite a while, and I haven't found all my answers, so here I am.
I've had all sorts of Toyotas, and a buddy of mine has a 76 FJ40. The engine spun a bearing or something and locked up , so we are getting the parts together to put a SBC in it. We have a complete engine, and the bellhousing adapter.
We haven't been able to find out a couple of things.
1. What's the correct flywheel?
2. What's the application for the clutch we need?
3. What's the best clutch master cylinder setup to use?
4. Will the stock starter work?
5. What's the best (i.e. cheapest) route as far as engine mounts goes?
Hunting season is here, and it's hard to sneak up on animals with my Dodge diesel:) We need to get his FJ going.
Thanks for the help, I've already learned a bunch.
Welcome!, you might also want to check with some of the vendors that are regulars here. Sometimes they offer used adaptors that will save you some $ You can also do a search of the forum, there is a goldmine of experience and info on this site.
clutch depends on what trainy you are useing. I know that with the 3speed in mine, I would use a gm fly+plat but with the 11in toy disc make or buy the new hanger for the toy slave cylinder and as far as the starter I have no real Idea but would think that you would have to use gm so it fits the flywheel teath or build a combo gm toy the toy with the gm bindix. Engen mounts I bout the offter market swap mounts but thin it would be cheaper to build some, also I have a friend that built a 31 ford model A and put in a 350 the mounts he got where like 25 bucks at the speed shop and would be easyly used for this app. Good luck
Downey Off Road is an excellent source for V-8 Chevota clutches. I sell the motor mount kits. You can call them to follow up on the clutch: 562-949-9494.
My info's below.
Hth
Mark A.
V
