So after about a year I deciding which 4x4 I should get for off-roading and 6 months of searching, I finally found a 1996 FZJ80 with lockers at a decent price. Now I am researching my guts out trying to find my sweet spot for mods and my style of off-roading.
I do not plan to beat it to death on rocks or push it to the limits. However, I do want a vehicle that will take me on some adventures. I live in Idaho so we do have some nasty roads in the mountains and in the country. I have gotten my relatively stock Jeep stuck or had to turn around to many times. I know I want to run at least 295/75/16s on the stock rims, but I am also considering 315/75/16s and a OME 2.5”. From what I have read some people think I would need to re-gear to go to the 315s, and some people think stock gears are fine. I bought this vehicle primarily for off-road, but I also need to drive it on the pavement to get there.
Logically, the taller the vehicle the less stabile it can become, so I’m thinking I might want to run 295s with stock suspension. However, I have read that this is only good for “light wheeling”? Is the limitation due to the tire size or rubbing and lack of flex? What is “light wheeling”?
I would get an OME 2.5” lift, but I’m concerned about castor and front driveline issues. The offset bushings seem pretty hokey. I don’t want to half #$$ this, yet I don’t want to dump $3000 into a suspension for 2” taller tires. I have spent years researching and messing with my Jeep so I am not new to the concepts, but the Land Cruiser is a different world.
So to recap….
1. 295/75/16s on stock suspension: Is the smaller size my limitation? Or is it the lack of flex and rubbing?
2. Do the OME 2.5” really effectively correct castor? Additionally, what is the difference between the SLEE OME 2.5” and the Rocky Mountain OME 2.5”?
3. One more! I noticed that most sliders do not weld on and actually use u-bolts?? Is the frame tempered? Is it not safe to weld on the frame?
4. I lied, one more: In the Jeep world “body lifts” are pretty frowned on. How about on a LC? It appears that a simple 1” body lift can be quite beneficial.
I honestly did search, but it’s like wading through a swamp to find a flower……hopefully you guys are not as flamey as the guys on Pirate4x4!
THANKS!!!
So to recap….
THANKS!!!
. Get used to the symbol. It is your friend.
<-- what the hell is that? Mr. Yuk?
