NEW GEARS...Front diff temperature vs rear?????
Pineville, Ky
Just re geared the 80 to 4.88's and installed front and rear arbs.... I'm in the break-in phase and the front diff seams to be running noticeably warmer than the rear... to the touch it is much cooler than the t-case after 15 ro 20 minute drives... my question is does anyone have a temperature that is "normal" for diffs and t-case to run?
I don't have any numbers, but remember the front diff is sitting right under a big hot motor. Radiant heat is almost always going to keep it warmer than the rear. A 10 to 15 degree difference seems like it could be pretty normal.
Just measured my front diff (had oil leak, fixed, longer story). After 60 min of highway driving (65-75 mph) the front diff was at 156 F at hottest point as measured with IR thermometer. Rear diff was at 107 F. Ambient was ~60 F
Hoping this is normal!
All the above.
"had oil leak, fixed, longer story"
@Octous
Where was the leak, pinion seal?
How did you fix it (technique for tightening the pinion nut)?
Was the front diff driven low on gear oil (due to the leak)?
Was the front diff making noise (howl/whine/rumble, worse with increased speed??) before (or after) you fixed the leak?
What gears (stock or ?) are you running, rebuilt diff?
Any increase amount of metallic debris on the drain plug magnet?
What weight gear oil, conventional or synthetic?
Stock truck or modified, long uphill run when temps were checked?
Was (is) the front diff gear oil clean or contaminated?
Black/green "milk shake" from grease (or water) ---?
All the above.
Passenger side CV axle seal
Replaced seal and axle
yes, but not for very long and when oil drained got out about 1.1 litres (fill is 1.6 l)
No chunks
Didn't have any funny noises before leak. Doesn't seem to have funny noises now . . .but hard to tell there might be something but I think I'm just being paranoid.
Stock gearing, but Nitto gears replaced 3 years ago.
Nope
Mobil Devrac 75W-90
Long climb on highway 92 from hwy 280 to hwy 1. Then down hill on the otherside. Pulled into driveway and checked temperature.
Clean
Clean, not contaminated by grease or water.
