New custom transfer case shift knob
hoser said:
Just a note: I have an aluminum shift knob in a black car with black interior and the knob is not friendly to the bare skin in hot weather. But at least the 100 doesn't have a manual transmission where you have to continually shift.
Im out. It's nothing but sunny hot weather where the 05 lives.
I live in south Louisiana where during the summer it is routinely 100-105* and had the aluminum transmission and transfer case shifter. Yes they got warm, but never hot.
IMO, especially with the transfer case shifter, summer heat is a non-issue.
How about orange?
As of right now, those are the only finishes that i know of that he has, with the exception that he is working on a green anodized finish.
Welcome to Ellisprecision.ca
If you click on a color it shows you a photo of a battery clamp with that color anodizing.
I am setting up the group buy thread right now, so check the first post in a few minutes for a link to it.
To those asking about transmission shifters, if you are wanting a design different than the one for the FJ Cruisers, it would probably be a good while. It took him a good while to be able to have the time to design this one for me and get it made, but now he is setup to crank them out quickly.
It's only a problem when sitting in the sun with the windows closed.... so add 15-20 degrees and it'll be 120-125 in there. Black paint with black leather probably a bit more.
But yeah, t-case probably no big deal.
If i had a manual transmission, yeah it would suck hahaha.
Would it be possible for him to build an extension into the knob? This would help people running body lifts.
I forgot to mention that.
I'll ask him about an option for folks with body lifts.
Any word on that? Shouldn't change the design too much. If yes, I'm in for at least one (possibly two).
I sent him a PM last night on the FJ Cruiser forum asking about that.
After thinking over some options i think i might have figured out an easy solution. The TC knobs allow the screw to sit inside the knob fairly deep, in the same way the stock one does. If he made the entire thing solid, and then just drilled and tapped the hole from the bottom, this would add about an extra inch or so to how high the knob sat.
Does that make sense?
edit:
Just spoke to Joel and he said he can make them like i mentioned above no problem, which should give about an inch extra of height at the bottom of the knob.
There is only one small issue. The way you orient the knob so that it faces in the correct direction is using two jam nuts (see picture below). You set these, screw on the knob, check the position, and then adjust accordingly so that the knob faces at the correct angle. If creating a knob like above, that would put both of these jam nuts below the actual knob and be visible. However, since you could now access the nuts, you can get away with just running one under the knob, hold it with a wrench, and then tighten the knob, adjust as needed. It'd be pretty hard to see one of the nuts under the knob.
Locktite would solve the alignment issue, and be a lot simpler. I could do the same with the stock one, but since it's so short to begin with it doesn't get you all the much extra room unless you're exposing a bunch of the thread (looks tacky).
But yeah, I think I see what you're saying.
really the most help would be if anyone is or know someone who is parting out a truck and can send me the shifter assembly then i can get some real work done very quickly.
I can get this
But do you need just the shifter itself? Or the shifter with all the push button attachments?
I have an 03 which has no buttons on the trans shifter. The only hold UP would be threading. I want 2 matching handles in black. Will the insert on the trans show LC or TEQ in Japanese?
Nevermind...I saw the group buy link above...
Sent from my EVO using IH8MUD
bump.
These are made and ready to ship out. Joel did make a few extras of the transfer case knobs if you are wanting one for your 80 or 100 series.
If so, shoot him an email at
joelellis767@hotmail.com
Just tell him these are the shift knobs you read about on ih8mud for the Land Cruisers.
bump.
Anyone know of a new source for this type of transfer case knob? Thanks!
Looking for a Knob as well.
