Hello everyone, been lurking here for a couple months and finally joined, seems like a great community!
Bought a 97 lx450 a few months back and been driving it around to find a whole slew of problems, 2 I'd like to address.
Should add a little background info also, got the truck with 207k, drive it to 210, got a factory oil filter and oil and replaced it, and since have driven another 3k, so 6k total)
Firstly when I purchased and began driving the truck the oil pressure gauge worked, after a week or two it stopped? Now it always sits on the L and makes no effort to move. At one point I didn't use the truck for a week or so and when I did again it suddenly had started working, for about 30 minutes, increased/decreased under load properly while it was working however. Hasn't come back since, what can cause this and how can I check it before throwing money at it ?
My assumption would be the, oil
Pressure sensor? Possible bad oil pump? Don't know much about these, I should mention it's a 1fz-fe.
It could be related to my second problem?
Since I got the truck it's had a noisy tick, it's consistent with rpms and more noticeable at lower rpms. I assumed the valves needed adjusting and had it taken to a shop, mechanic said the camshafts (lobes?) are worn and that's causing the noise, it was possible starved for oil at some point (brings me back to the oil pump? But pressure did work originally and for the one short period, could pump start and stop?) does this sound reasonable or is the mechanic looking to make a buck? I don't have any local scrap yards with landcruisers to pick at, where can I get some reasonably priced used cams?
Thanks in advance for any info, much appreciated!
