Howdy everyone, longtime lurker here.
I have a bone stock '95 22RE, 5spd, 4x4 DLX w/125k miles.
I was having trouble shifting into first from a stop and had to pump the clutch a bit to get it into gear. Wanting to avoid jumping right into a clutch replacement, I went for the easier/cheaper things that might be the problem.
A search of the forum here said that it might be the master or slave clutch cylinders. I got both from NAPA and R&R'd them. When I tried to bleed the system, it initially went well, building up pressure. The slave didn't seem to move as much as it should have, but I thought it was OK.
I tried to go for a test drive, the clutch had no pressure at all, the same symptom as the old master.
I thought I bled it properly. There are no leaks around either the master or slave. Could the rubber hose portion of the system just above the slave have a leak that I can't see?
I'll take any ideas; good, bad or unusual.
Thanks------->Al
'95 DLX, 4x4, 5spd, stock
Thanks------->Al
