New Clunk Fix!!
Kansas City, Missouri
With all this Clunking going around on the 100 forum, I figured I would add a post for you guys searching for a potential reasons why you are getting a clunking noise out of the rear of your rig.
I was getting a clunking noise out of the back of my truck when I went over speed bumps and other bumps in the road, typically at slower speeds. I did some searching on this forum and decided to clean and grease my drive shafts as suggested and this did not fix my problem although I am very happy I did this as it needed to be done anyway.
I figured I would crawl under the truck and knock on some things to see if I get a rattle in the suspension as I had just installed an OME lift and shocks about 3 weeks prior to this knocking noise appearing. The noise was coming from the rear passenger side of the truck so I started on the rear drivers side and took a rubber hammer and started tapping on suspension parts and only got really solid sounds when tapping the Spring, Shock, Sway Bar, etc... I then went to the Rear Passenger side and started the tapping process. Tapped the Shock, Sway bar and all sounded solid until I tapped the Rear Passenger Spring. When I hit the Spring I got a big rattle noise! BINGO... Found my issue...
After examining the spring I noticed it was not seated correctly on the lower spring perch. My spring needed to be twisted a bit to get seated correctly. Took 5 min to jack up truck twist the spring a bit and lower truck. Tapped on the spring again and solid as a rock with no noise. I no longer have the Clucking noise when going over bumps.
So, for those of you trying to track down a rear clink, knock, rattle or any other description of noise in the rear of your rig, check out your springs and make sure they are seated correctly as this may be your issue. If not, look at the other treads on this board and they may help you out.
In doing my search to find out what "My" issue was I did not find anything mentioning Spring seating as a potential reason for a rear noise. Hope this helps someone on the board fix there clunk, clink, knock, rattle or what ever noise they are getting! :rolleyes:
Zane
Thanks for taking the time to write it up.
Once you rotated it, did it look like it would stay in place?
I only had to move it about a quarter of an inch, if that so it is now resting in the correct location.
