neutral safety switch
Rio Rancho, NM
Wiring harness is buggered and I found where po has connected wires with butt connectors where there should be a harness connector. Unfortunately I found one wire is not connected to anything.Its yellow and comes from NSS to harness. Does anyone know what it's for and what is best way to mitigate this situation other then new harness.
1st pic is what I have. 2nd pic is what is half of of what should be there.
you would recognize those .. in my 80 ( 95 ) they were a thick probably AWG 10 or so .. black and white. All others are like 16 or 18
I uploaded the Transmission control pages from the EWD for your amusement. This is for a 1996 FZJ80, so keep that in mind as we have different transmissions.
You can see where the Yellow wire goes to. Looks like from pin #4 on the NSS (pg 134) to pin #2 on the Transfer low position switch (pg 132).
Another yellow wire is used to take power from the battery (pg 133) to the OD OFF/ON input on the dash light (pg 134). Again, not sure if the '94 has OD on/off push button on the shifter lever.
Thanks Ali, appreciate that,I have no idea how to read those. I will print it and give whomever can explain it in English, in person, a whiskey drink.
BTW I do have the OD/off switch and it did light up on the dash so now I don't know what else it could be.
Also if anyone has a trashed transmission and or a NSS they are willing to sell cheap or just the harness wire cut off near the unit would be even better. I cant get the intake off without removing the harness and the PO spliced it instead of fixing/putting on another harness connecter. So I have to either cut the wires and re-splice after engine is placed back in, which is not a good location or fix this now while its easy with harness connectors. I have half (on donor harness)need the NSS to harness connector.
So, just to confirm, this harness is different in the 94 vs. the 95? I'm dismantling my 95 and if it's the same I could help you out.
MDarius, they are different. Thanks though for the thought. I will need a 91-94 NSS wire loom
