Help needed ASAP.
I've recently discovered that my passenger front is leaking something. I'm thinking it is gear oil. It's splashed out on the back side of the tire in 360*. I had a similar thing happening a couple years ago when a rear axle seal had let go. Also, the sucker has recently started vibrating me right outta my seat while I'm driving it. I had some small vibes goin' on for a while now, but recently has gotten really bad. Only thing I can think of is that I drove it around in 4WD last week when I was out late during a snow storm and the streets were covered with ice and snow. As soon as I hit dry pavement though, I pulled it outta 4WD, but I did leave the hubs engaged for about a day longer... And lastly, I've also noticed a new noise that seems to be coming from underneath the rig somewhere (could very well be from the passenger front knuckle/axle area...) that sounds kind of like rattling chain link. I've noticed it when I have just been cruising slowly through a parking lot (though it could still be going on at higher speeds, perhaps I just can't hear it over all the other noises...) I thought at first that it was loose drive shaft bolts cause that happened to me once and it sounded similar, but i've checked my driveshafts 100 times and they are tight... Perhaps it's my bearings in my passenger front....? Or diff bearings 'cause all the gear oil has leaked out the end of the axle tube...? But, the front diff is not engaged, so I wouldn't think it would be rattling all the time...
Anyway, I'm pretty sure I gotta tear into the passenger front for sure, but I just wanted to see what you all thought first. Should I have a kuckle rebuild kit on hand when I do? (Kurt, you got any?)
-Ferg-
-Ferg-
) but gonna tighten that sucker up and see what happens. Dunno what the vibes and noises all were, but obviously somethin' wasn't right with the caliper...
