Negative Battery Terminal Help
Cincinnati, OH
I messed up the nut on the negative side so now i have to cut the cable and terminal off.
When i go to put a new battery and terminal in i will need more cable since it will now be cut too short. Do i just get some extra cable and crimp it on, or do i have to find out where the negative side ends up.
If i have to figure out where the negative send ends up, could someone tell me where it ends up and how big of a pain in the ass it would be to replace.
Can't you replace the nut? I would spend some time trying to fix the damage before trying to put new ends on my cables (and that's what I do for a living). Is the nut seized on or something?
i guess the nut is stripped, its too big for an 8mm and too small for a 9mm. I dont know what else to do but cut apart the wire from the terminal
vice-grips maybe? I'd rather destroy the nut before I jumped right to cutting the cable.
arg, its really that big a pain in the arse huh? I already tried the vicegrips, i'll give it another shot. I guess i will have to try and figure something else out.
I'd fix what you got or replace the whole thing. it is not bad to replace it terminates on the side of the block a bit aft of the oil filter just above the drivers side motor mount.
