needle valve....help!
Prince George, BC
My 1974 fj40 carb that I'm rebuilding has an adjustable needle valve inside the banjo fitting bolt on the fuel return fitting. I took it apart without thinking :doh: and I don't know where it was set or what will happen if it's not set properly. I can't find the valve in my Haynes manual (surprise surprise) and I don't have a factory manual yet. Does anyone know what this thing is for and how I set it? :confused:
moral of the story: don't attempt carb rebuilds if you're hung over :flipoff2:
This thing? Looks like it's some kinda flow restrictor or somethin...I don't recall ever having to fiddle with it. Looks like if you screw it all the way in, it would stop the fuel return completely, that wouldn't be a good thing. But what happens if you don't screw it far enough in? Fuel returns too easily? I dunno.
But, I've got a fresh Jim C. rebuilt carb in the Pig now, looks like it's (the threaded plug thingie) been turned in maybe 5 or 6 turns. And since you only have 10 or 11 full turns before it bottoms out, I'd screw it in halfway (5 or 6 turns) and see what happens.
