needing some suggestions
DFW, TX
So I am troubleshooting a #5 cylinder misfire. Anyway, I have about a week off in October so I've decided to work on the truck a bit. It is no longer my DD so I am not really trying to work on a deadline; it not being put back together is not really a priority. My plan at the moment is to take out all the injectors, have someone clean them, give me a breakdown of what/if any issues were wrong, see if I can cross this one off the list. Have 314k miles so I have no idea if it has ever been done to be honest prior to my ownership.
I want to find a good place to take them to or send the injectors off to have this done, so any suggestions on this from anyone? I have seen some mentions before when searching, but nothing too recent.
Also, since I have some extended free time, I wanted to see if any of you had suggestions on anything else I should work on as I will be tearing into this anyway. Basically I am trying to put together a plan so I can have misc. parts ready to go. My only other plan is to look at my power steering/cold-weather groaning and maybe misc hoses, oil leak at distributor and minor stuff.
Have you checked the injector wiring harness where is passes by the EGR pipe? I just opened mine up and repaired three wires that had the insulation burned through to resolve a intermittent misfire issue. From the outside the wiring harness looked ok, I had to peel back the layers before the damage was found.
It took me a long time to figure this out, I was sure it was something fuel related (filter, clogged injectors, etc...) and ended up replacing the fuel filter and ran a bunch of injector cleaner through to no avail.
I have, mine wasn't burned at all, but I am going to take the time to check it more thoroughly after I take things apart, rewrap after testing with multimeter.
It wouldn't be bad to send an oil sample to Blackstone and maybe do a leakdown test if you like having information on your side. You will see where the engine is for wear, as well as make sure you have no antifreeze sneaking past the hg. Leakdown will eliminate the possibility of low compression on #5. Otherwise doing maintenance replacements and checking that harness like @ZackR said. Good luck
it is a '96, the plugs were definitely worn, but I have seen worse. Oddly enough I thought #5 looked better than some of the others. All plugs, wires, rotor, cap were replaced but that didn't change a thing.
I am thinking I may just start with pulling the injectors, but once I have some things removed I will start poking around more, just do an overall inspection of wiring, hoses, etc. See what other things down on that side of the engine may need some preventative love, then order parts as I see fit.
I will have to check for clicking. I did start it up the first time in a week yesterday, first time I noticed a strong gasoline smell too. Thought it was going to stall how bad it was shuddering, slight incline on my driveway though.
