Need transmission advice
I bought a 1968 FJ40 this past fall. Had an FJ 40 34 years ago (I'm 66 now) just for a winter when I needed something to deliver newspapers in rural area during the winter in western N.Y. Last couple years got desire to get another one to work on. I am low on mechanical knowledge but admire those who are able to do this kind of work so I wanted to learn and hopefully end up with a vehicle I and rest of family (wife, kids, grandkids) can enjoy. I do have someone who has done restoration work that said he would work on it and let me help. At this time I'm just starting some research by asking questions, listening and learning.
The FJ has a small block chevy 350 in it. It has what I expect is the original 3 speed transmission. My question: The 3 speed transmission doesn't seem to be enough for higher speeds. Can a different manual transmission be installed that will enable it to run better at higher speeds?
I will include a couple pictures. I plan on installing the hard top instead of the soft top that is on it in the picture. The hard top is in great shape.
I appreciate any help you can give me and look forward to days ahead of what I hope can be accomplished with much help.
Thanks
Welcome to Mud, Roger.
You will want a moderator to move this to the 40-series forum, here: 40- & 55-Series Tech Currently, you are in the FJ Cruiser sub-forum, not the same thing at all.
Not easily. The later 4-speed transmissions still have the same 1:1 top gear as your 3-speed. The only 40-series transmission with an overdrive top gear is the H55 5-speed that came in the very last years of the 40's imported to the U.S., but it uses a different transfer case and emergency brake system, and the late axles with emergency brakes are harder to find.
You can do two other things to decrease engine rpm at highway speeds:
1) use larger-diameter tires; 33" is a common size that works well and will give you a "rubber overdrive", at the expense of losing some low-end grunt.
2) Install 3.70 differential gears (front and rear) from a late 40 or a 60-series; they are interchangeable. This will also sacrifice a little low-end grunt.
I have both of these on mine, and can cruise comfortably at 65 mph on the highway, at about 2600 rpm.
The bottom line is, these old trucks were never intended to go at modern freeway speeds. Rather, they are now an invitation to slow down, take the back roads, smell the roses, and enjoy a slower pace of life.
Enjoy your Cruiser and working on it. It will pay large dividends of satisfaction and fun.
Or maybe consider a NV4500 trans with a Advanced Adapters conversion kit. Or an automatic tranny with overdrive. Either 3.70 gears or oversize tires would be your cheapest route, or both.
Thanks for the information. Very helpful. Even though it's still like Greek to me I'm excited to begin this process and receive information that will move me out of my ignorance into the knowledge I need. Someone suggested a TH400 auto transmission or a land cruiser h42 with an adapter plate. Any thoughts on that?
Just saw this after I posted my other reply. Thanks for this information. My options are expanding.
Both of those choices have the final drive ratio of 1:1, which is the same as what you have now. No change in highway RPMs. To lower your RPMs at highway speed you will either have to go to an overdrive tranny or lower your gear ratios in the differentials or go to a larger tire. Your diffs should currently have 4.11:1 gears, an easy swap is to find 3.70:1 gears in later model third members and just swap 3rd members, but doing this will affect how slow your low range gear/speed is. Larger tires have the same effect.
I see that I should be on the 40 series forum so I will move my learning over there. Thanks again for your help.
FYI: Here is a link to a 5 speed swap into an older 40. The H55 has an overdrive 5th gear that would help. It is something I am considering myself with my 3 speed (would try to do this and a 3/4 tub at the same time so Im in the planning/saving phase.) 3 on the tree is cool, but I would like a few more gears and the linkage is keeping me from doing a power steering conversion. https://forum.ih8mud.com/threads/no...another-h55-splitcase-into-a-74-fj40.1004345/
Nothing interesting here, just another H55/splitcase into a 74 FJ40
If you want an overdrive auto I believe you would be looking at a 700r4 or 4L60e. If I were to do that I would get a complete engine and trans take out, possibly from a "ready to run" type company like Tilden that does the harness work. Then AA to the transfer case plus some drive shaft work
I recommend a GM 700R4 automatic transmission swap for many reasons:
1. Lower first gear for off roaring
2. Overdrive high gear for highway
3. Stronger than your stock 3 speed by far
4. Drive train cushioning (fluid drive, easier on the transfer-case)
5. Torque multiplication at the torque converter
6. Much better hill climber than stick shift
7. No shifting
8. MOST IMPORTANT: Mama will love it!!!!!
With all that said, check out ebay #262541590093 for more info on this subject.
