Need tool recommendation
SoCal
Have a bolt that's busted off. Luckily not in a critical area. What is the best easy-out set to get. I have a sinking feeling this will not be a one time problem. Thanks.
Vic
Redlands, CA.
My answer varies depending on the location of the bolt.;p
AND the size.
Fair question. 1/4", might be 3/16th's, and it's in a pivot for swing arm on my aftermarket bumper. So if I screw it up I think I can drill out and tap to a slightly larger diameter, but sure don't want to.
Now I'm thinkin that we're talkin about that big-ass tire carrier, TRIPLE can holder on the back of your F-O-R-D, are'nt we? If that's the case, just drill it out; a] it's a PITA when the easy out breaks off and you've got to worry about getting tool steel out of the way, and b] that tire carrier needs bigger bolts anyways for the load it's carrying!
Best
Mark A.
I hear you Mark..... if there is a little stud left, I usually find a nut that will fit over the broken portion and weld it in the center of the nut-hole. then I let it cool very much and PB blast(penatrant) it for a while and let it soak in. I then turn it BOTH ways slowly back and forth until I work the offensive part in the direction I want to go.
AND the size.
Don't forget the left-handed drill bit approach. and Kroil. plenty of Kroil.
PB Blaster didn't work for me but, then again, the bolts were rusted pretty well. I had to drill all of them out but I was able to retap using the same size. This was on my top, sides, spare tire carrier and tail gate....
Hit it several times with a BFH and let it soak for a while and repeat the process as you see fit.
:lol: I always love the technical insight provided on ih8mud. :lol:
gotta love that attitude eh? i personally HATE easy outs with a passion, i have had like 4 break on me and then i cant get the bolt out ne more cause i have tool steel stuck in the hole so....what i would do option 1: BFH, heat then try wrenching it out. option 2: left handed drill bits with lots of lube whatever type floats your boat
I don't use easy outs anymore either, they break off too easy. If you have a welder, just find a nut a little larger (providing you have some bolt stickout) & weld it fully inside the nut. If it's a flush break, I drill into the broken stud, break off an easy out so you can have something to weld to, then repeat the welding process above.
Hey Vic. You still here?:confused:
I think that easy-outs are contraindicated in any bolt that breaks off when you are trying to REMOVE it. If you break it by overtorquing while installing, or it shears off for some reason, they should work. If it broke becasue it is too rusted/frozen, you will never beat the torque you had on the hex of the bolt in the first place.
Lots of lube/heat/hammering and then reverse drill bits are the best and always be ready to re-tap.
