Need to repair/replace "Y" downpipe
Folsom, CA
After way too long, I finally collected all the pieces I needed to replace my cats which failed due to a leak in the "Y" downpipe joint. I found a good front cat from a wrecked 80, but the down pipe was partially crushed, so I cut the "new" cat off the crushed downpipe with plans to weld it up to my downpipe after I repaired the leak. Unfortunately when I cut my downpipe just below the "Y" I found that it had failed due to corrosion. The flat faces on the two incoming pipes were nearly paper thin. (see first two photos, the third is what it is supposed to look like - unfortunately from the crushed downpipe) There isn't much left to weld, though I am contemplating trying to braze it. So, I am looking for suggestions on repairing this downpipe, if possible.
Failing that, does anyone have a good downpipe available? I don't need another cat and am hoping I might be able to find a good downpipe here in Sacramento. CARB doesn't allow junkyards to sell used cats, so they typically cut them off and sell them for scrap. I am hoping they just torch them off and that I might be able to get the remainder of the downpipe from the truck. I'll check tomorrow but imagine they will not be open until Monday.
Thanks,
I too am looking for a replacement Y pipe. I've heard the OEM ones are silly expensive. My current one has already been reworked by a muffler shop before I bought the truck. I've been trying to track down a loud buzz/rattle that appears to come from the area of the Y pipe. I've removed any brackets and heat shields that can be removed. The cats, heat shields and mounts look good. I suspect one of the booger welds on the Y pipe is cracked. Does anyone make aftermarket components like the Y pipe or are those always custom fabbed by muffler shops?
While we're on exhaust systems.....
Why isn't there any type of a flex joint between the engine and the cats? On many cars with transverse monted engines, there is a flex joint to allow the engine move on the mounts without stressing the entire exhaust system. On my FJ60, the exhaust was routed inside the frame very close the the transmission. When the engine was under higher torque, the exhaust didn't need to flex much. On the FZJ80 with the exhaust outside the frame, a slight movement of the engine requires a significant movement in the exhaust pipe unless the pipe is flexing - no wonder the Y pipe fails. I saw an HJ75 with the same arrangement: rigid pipe leading off the exhaust manifold and down outside the frame. Engine torque had caused the pipe to fail.
Has anyone added a flex joint to the system?
Discount Converters has them for around $250
http://www.discountconverter.com/
I checked their website and they don't show any direct Toyota applications later than 1995, which is when OBD-II kicked in. The problem in Kalifornia is that CARB must certify any non-OEM cats for OBD-II vehicles and thus far I have not found any companies that offer that product. Do you happen to know if one of thier universal types fits and is 50 state legal?
Of course, that still doesn't solve the problem with the Y pipe...
How will Cailfornia emissions know? Were 1996 trucks not all built to comply with Federal Emissions?
Thanks for the link! If I can't find a used Y pipe in good shape that is a great backup plan.
With regard to Kalifornia emissions, depending on the tech, it will fail the visual before they even hook it up to the analyzer. I have Hanna skid plates which would make it more difficult to detect, but it's still a risk. However, since I do have a good Toyota front cat now, I could buy that setup on ebay for $300, cut off their cat, and weld on the OEM cat. I know it seems wasteful, but it would probably cost nearly that much to have a new Y pipe made from scratch.
Cheers,
The stuff on ebay looks like it was made out of a low grade steel; hard to tell of course from a photo, I sent the seller a question about the steel, etc; will see what they say.
I would think that a custom muffler shop (not one of the chains) could weld up
a Y-pipe for you out of a high grade stainless for not much more than some cheap stuff off of ebay??
You have the cat and the flanges; all they would have to do is get the bends and collector right.
G
G
The photo on the eBay auction is the same as the one on the Bosalna site, thought they are supposedly made by Davidco or somesuch. Please post what you hear back from the vendor.
I'll check with the local muffler shops to see what they quote to make up a new downpipe, though it won't be stainless because I have to weld it to the cat.
Cheers,
Cheers,
The OEM exhaust is all stainless; if you bring your cat and flanges
to a shop that can do it with stainless (if they know how to work with stainless, if not, go somewhere else), they can weld it all up for you, it would actually be better (for you) if they did the entire job.
ie: if you screw it up, you eat it, if they screw it up, they get to
do it again.
g
You know, after looking at the inside of the Y-pipe at the collector, I am wondering if the infamous 80 exhaust whistle is maybe produced at this point?
Anyone ever run their 80 with just the Y-pipe, and still hear the whistle??
g
http://www.cruiserparts.net/parts/fj80.htm has some CATS new and used. You may have to call or email to see if they are Kalifornia certified
17410-61240
17410-61200 1991-1992 Brand new replacement, Left or Right comes with down pipes. $349
91-92 Used factory Toyota. $250
1993/94 New factory Toyota $399
17401-66090 1995-1997 Brand new replacement catalytic converter, Front $399
18450-66120 1995-1997 Brand new replacement catalytic converter, Rear $249
g
I posted that observation in your whistle thread. I don't recall an answer.
do it again.
g
OEM is stainless?? Mine sure is rusted for being stainless! I know stainless will corrode, but I would have sworn this was mild steel, given its condition. I guess I better go take another look, thanks.
g
My 80 was whistling, which is how I found out it was cracked. I could also feel exhaust puffing out from the Y when I held my hand up there. I was one week away from a trip to Baja, so I welded up what I could (there were cracks going 3/4 of the way around) and packed muffler paste in the slot between the downpipes. The whistle disappeared. The repair held for a while, but I got a P0420 (insufficient cat function) late in the trip and the whistle came back. About three weeks later my front cat grid collapsed driving home from work. I assume it overheated due to unburned fuel reacting in the bottom. I am guessing the front O2 sensor was reading a lean condition due air being sucked in the crack, so the computer was running the engine in a rich condition. I know my mileage was down.
I just removed the engine from my 94, the exhaust seems to be pretty good. Unfortunately I cut the exhaust around the front mud flap. Where is the Y pipe and what does it look like? I am willing to give mine away (if I didn't destroy it) if someone is willing to pay the shipping.
Rusty
Rusty
The Y-pipe refers to the two exhaust pipes that come down off the
engine, then are joined together to make one slightly larger pipe
that goes a short distance before it goes into the first cat, hence Y designation.
If you cut yours off at the mudflap, it should have been beyond the
Y, but before the first catalytic convertor; correct?
G
Rusty
Rusty,
If you cut it off anywhere south (towards the cat) of the Y joint, I'd be happy to take it off your hands. ;) The Y pipe is just down stream of the exhaust manifold. You can see it if you look through the right front wheel well just behind the tire. The Y is about even with the frame, give or take. Have you removed the exhaust manifold yet?
Cheers,
Rod
