I want some input from people more knowledgeable than me on poss engine problems. Long read I know just trying to cover my bases.
My truck is a '97 with 185100 miles. I bought it almost a year ago with 170kish miles. Im the third owner and it had decent records. So far it's run good and been a great Cruiser. Still original head gasket best I can tell from the records.
Here are the issues. Within the last 6weeks Ive done cap, rotor, plug wires, and valve cover gasket. After doing the above I noticed a slight valve clatter under load. A Toyota mechanic friend suggested the distributor was prob off. In trying to realign the distributor I backed out the crank bolt. Got it all back together and it seemingly ran fine. But the valve clatter persisted. I have noticed since the tune up and before the crank bolt issue a slight noise that I thought was coming the bottom end but I never could pin point. It wasnt consistent and seemed to be independent of engine rpm.I could only hear it from outside the truck.
This morning I went out to go on a little trip and with it being in the teens last night I popped the hood to check around. Coolant resevoir is dry. Added to it back to the fill line to see what happens. Pulled the dipstick and it looked like a few tiny ice crystals or fine metal shavings on the end. Looks like a fine layer of chocolate milk under the oil cap. Drained the oil and it looks like used black oil with a sweet smell. Only has 2500 miles on it. The truck still makes good power and my MPG went up by 2 since the tune up.
Ive got a bottle of oil ready to go to Blackstone just for giggles to see what shows. With fresh oil in now, the bottom end sounding noise seems to be gone.
Last oil analysis 2500 miles ago showed a slight lead increase that was noted as possibly being a particle streak that would clear after an oil change. But the lead wasnt high enough per them to be alarming. Eveything else was perfect and looked good for a 180k mile engine. I remember now when I was turning the crank to align the timing marks it seemed thru some of the turn it was pretty easy but at one point in the sweep it was harder to turn. Was that a sign of a bad cylinder?
Im pretty positive on the head gasket being part of the problem. The bottom noises Im not sure on. Do I try and rebuild this one or write it off and get a known good used engine and have it swapped in? Im not sure what a rebuild would cost. Im seeing known good used engines for under $2k and I can prob get the lead mechanic at work to take it as a side job one weekend with my help.
Or do a head gasket and see what happens knowing the bottom end may have to be addressed. I need to minimize down time and exspense best I can. Im just not sure where to go from here.
