OK so i lifted my 80 (j springs) and i started getting a weird vibration. I currently do not have any extra weight in my truck (will be adding some soon) and other than the lift and front DC DS, my truck is stock.
The vibration sounds like it is coming from the rear. It only makes the sound when i let off the gas above 30 mph. Once i engage the throttle again, the sound goes away. The closest noise i can think of to it is the sound you hear when you go over the rumble strips on the highway. Recently, my friend and i loaded my truck down with ~300 lbs of people/ concrete block in the back and the sounds almost completely went away. I did still hear it on occasion, but it was tons better. I already replaced the u-joints on the rear DS and that did not seem to help the noise.
So here are my questions. Is this noise because of the angle that my rear DS has due to my lift w/o extra weight in the rear? OR Is something else (possibly pinion bearing or T-case Bearing) going bad? If so how do i try to figure out what it is? If it is the angle of my DS, then i assume a DC rear DS would fix my issue. Is this correct?
Any ideas or insight are greatly appreciated. Like i said before, i am going to be putting more weight in the rear in the future, but like most projects, its going to take me some time to get there. I really want to get my truck on the road again without the vibration. Also, i wanted to have a better idea what is wrong before i go out and start buying parts just to find out it is something else.
Sorry if there is a post out there on this already. I read a few on vibrations and could not tell if they were the same as what i was having issues with so i decided to post my issues.
Thanks, Brian
Thanks for the help.
Thanks, Brian
