Need some help please!
Saint Helens, OR.
So On my way to the coast today my 97 FZJ80 overheated. I noticed the check engine light came on while driving and then noticed that my temperature gauge was all the way up!! 😭 pulled over then the coolant in the reservoir was boiling and there were coolant all over underneath the rig on the passenger side. I scan the code and it came up as P0115 i think.. it was the coolant temperature sensor circuit malfunction. anyway got it towed home when I started it just so I can get out of the road and pull it on my driveway, the rig seems to be running on 5 cylinder. It was misfiring! Can anyone here give me an idea What this was besides the fact that I over heated?
Thank you in advance!
A head gasket leak could explain what you see. Check your oil for signs of water/coolant; does it look like a milk shake?
I'm sorry for your lost .....
Maybe a head gasket, I maybe can come by and look at it sunday
Yup, sounds like head gasket. It's probably missing from the coolant in the cylinder or the lack of compression in that cylinder.
Do the prechecks, compression check, leak down, pull plugs, coolant pressure test etc
I checked the oil and seemed normal to me. It was clean and right bellow the "Full" mark of dipstick. No "milkshake" sign under the oil filler cap either
Was the coolant on the pass side coming out by the exhaust pipe or cat area?
I had very similar symptoms and mine was the head gasket. It is the lucky side of the failure, exhaust to coolant instead of coolant to oil, but still a big repair.
Im losing my mind already as I need this rig. I do not have the capacity nor the right tool and time and money to replace the head gasket (assuming it is the HG) Right now I am down to just motorcycle and its not exactly good riding day everyday here in Oregon 😓
... I scan the code and it came up as P0115 i think.. ...
I think,,, needs to be confirmed. What other code(s)?
P0115 indicates a problem with the ECU temp sensor. If it reads -40F, assumes open circuit, if 284F assumes a short. Or could be that it was that hot, if so :eek:!
That sucks, good luck with your rig. It sounds like another head gasket thread. Don't give up on your rig. Do whatever it takes to fix it. It is worth it
