Need some help over here!
Sorry if this isn't the place.
So me being dumb has created a bigger issue. Now I need to fix it. Just got my first 80 series. Came with one key. One thing I found out is that the key locks on the doors don't work. I don't know why, didn't get that far. So in the process of figuring that out i snapped my one and only key in the door lock. To deep to grab with pliars :banghead:. So I'm wondering if there's a way I can take off this metal piece covering the lock so I can get some tools in there to fish it out. I've searched and found nothing. Any help is appreciated.
That number on the side of the lock cylinder might be helpful to a locksmith. I think both your doors are the same original and the ignition lock has been replaced.
Once you find a key that fits the doors, make sure it opens the back hatch (under the toyota rectangular part at the center) too.
Save the bits of your key as is. A competent locksmith can make a new key from the parts. That will fit your ignition. Only get one made. Extra keys are a tremendous waste of money.
Another possibility is to go to the dealer to get a new door key made from the VIN. You will need proof of ownership for this. Mine cost less than $20 for two keys that are cut on a code machine.
Had AAA come out. Cut me 2 new keys for $60. Work fine. And you'd think it would be just the ignition but my key only works for the ignition and the rear hatch so the locksmith told me to buy new door locks and he'll make them work with the ignition key. So I'll probably just go that route cause as of now I can't lock my car unless I want to crawl through the trunk
