Need some advice
San Diego
So..... This week I decided to part with my 3rd gen due to the amount of rust due to lack of care from the previous owner. On a high note I was able to get a FZJ80 for a couple bills. Thing is a freaking tank. Today hired someone to detail engine and exterior while I was gone for the day. I get home and see him power washing my engine bay. My worst thoughts came true when I told him to turn over the engine..... It runs but after a minute the CEL light came on. Any suggestions? Greatly appreciated....
Check the code, that is a great start. Might be something easy.
Its likely going to be no big deal but if you got a code I would bet its a PO3xx which means that water got under the valve cover plastic inserts and UNDER the spark plug boot and made its way into the spark plug tube in the head. Its not a huge deal, just stuff a paper towel in there to dry the water out.
Drive it easily for a while, it will dry out and be fine! I sprayed my engine down at the car wash at christmas after blowing a rad hose, ran like s*** off and on for the day, it just needs to dry out. DO NOT try to get on any sort of freeway! That is when it will bog down and leave you going OH SH&^!
Grats, ha, ha I gave you your 1st like...
Get the code...
Just drive it...
Water in plugs. Or water in distributor cap. Drive it.
Or do like @NLXTACY said about the paper towels in the plug holes. And take out the three screws that hold your distributor cap on and dump the water out and blow dry it.
Very common to get water in the dizzy via the. Eng hole near the top of the base. Most often cases a 300/306 code due to #6 is at the lowest part off dizzy cap. Drive easy/normal until engine runs smoothly. Then check and clea codes. Probably will not come back.
Like said, needs a good running to dry it out, and codes be damned until then.
You may need to get out the air compressor to help it along, and frankly greasing all the engine bay sockets does WONDERS for repeatable reliabilty & running.
The only thing you don't over-grease on an 80 is the birfs - everything else is fair game. And if it's new to your way of doing, white lithium or dielectric grease are what the engine bay sockets like.
And maybe the guy did you a favor, this way you get to check the cap & rotor, and pop loose the plug end leads to blow out any water shorts.
Once you grease the sockets you can pressure wash the motor with care & it is fine, mine gets it whenever I feel like I need to.
Also if the guy got down low, this is primetime to drop some cardboard & start watching where & how much "blowdown" oil you have. They all drip unless you have gone bat$hit on seals & gaskets, it's normal.
Neighbor just did this (pressure wash engine) to his Altima after changing the valve cover gasket, comes pounding on my door freaking out. Wet dizzy and water in the plug holes. Blew both out using my air compressor and cleared the code with my scanner, ran just like it used to.
Did you mock him for driving an Altima?!
Pot calling the kettle black in my case as I used to drive a newer model one myself lol. But now I have a Camry, and a T100 lol.
Alright thank you guys, do you think waiting is good to let it dry??? hahaha... And if I do have to run it do you think its safe to just leave it on in my driveway for a little while?
Hahaha thanks sounds like a good bit of advice
At least pull the cap & wipe it, the rotor, and scrape / light sand off any corrosion on it. You gotta do some stuff, this is one.
Then if it were mine I'd let it idle in the driveway if it is running like a real turd, but yes - once you get past that, run around some surface streets, kill some time doing a few laps or so in your "safe zone". AKA cell & tow coverage zones (or in my 1 horse town, close enough you can get a buddy with a tow strap to show up).
Not to try & scare you, I'm just not right there to hear the level of turdness it's acting.
Then clear all the codes, they are semi-junk info. Not actionable enough I'd have faith in to toss $$ at parts over.
Once cleared & you been good & hot (still may need to blast w/ the ol' air nozzle) - and really, still grease those sockets / terminals - it's dead cheap and the return on investment is there. It's also a good excercise so you really LOOK at the motor, the leaks & seeping fluid spots, the belts, the pulleys, any ghetto fabbed PO crap, etc.
Just don't lean on the radiator overflow tank port off the radiator. (Nipple under the radiator cap).
That will land you back here asking about radiator vendors & the cooling system;)
x2. Ask me how I know.
Update everything works the way iT should, I let it sit over night and it's running perfectly now. Gonna go pick up some greaser. Next thing I found was that there's a leak from Thebes's rain in the driver side speaker! Good thing I'm not worried about the carpet yet
