Need some advice before I order.
Lakehouse
I am in the process of my rebuild.
I have a 4" BDS lift. I am now needing to order shackles. I am planning on getting stock length greasable shackles and greasable pins for both front and rear. Is there any reason I should get a longer shackle instead of stock length?
I have also read of several people using shims for the axles to correct pinion angle with their 4 inch lifts, but there seem to be many others who do not use these. Right now I am thinking that I do not need to use shims based on the fact that there does not seem to be a strong consensus in any of the posts that it is a necessary part of the 4" lift.
Is this something that I will find out I need when I get it all together and drive it, or is it soemthing that will need to be done now?
I have read alot of threads on this and I know that there may be several answers to the questions above, but I need some final advice before I actually break out the checkbook and possibly purchase something that won't work.
Hi,
I can only say my 2.5" Safari lift from MAF didn't seem to need any shims.
Love from a fellow Texan (hill country),
jim
I have longer than stock shackles on my 75. I based the length on spring flex my rears are @ 2" longer and the fronts @1". I didn't shim the front axle and should have 2 hands on the wheel and keep it under 60 mph. I have a saginaw p/s set up so road feel is very lite and with out the shims it tends to wonder.
The spring lift should cause no problems, but the shackle lift will rotate the pinion up and the caster may go from 1*+ to -. That will cause handling problems. Rotating in the rear(via shackle lift) will point the pinion up and may cause driveshaft vibrations.
Did you have to lengthen your driveshafts? I did. Also had to use shims in the rear to point the pinion back down.
See here...http://www.4xshaft.com/driveline101.html
GL
Ed
So if I only use my spring lift and do not use extended shackles, I should not have to worry about caster and/or pinion angles beforehand but could possibly afterward? In which case it would most likely be better to put it together and see.
Does a 4 inch lift require longer shackles to keep the shackle angle correct or will I be OK with stock length shackles?
The driveshaft issue is something I did not think about, but I should be able to determine and correct that issue a little later in the game if needed. That is a good link, thanks Ed.
Anyone else had driveshaft issues with a 4 inch spring lift?
You'll know if you need CV's when/if your DS vibrate like a somebeatch.
I say put it together and deal with the problems it causes later. You'll know what you need to do.
I have 4" BDS on my FJ40 with stock shackles. I also have an SBC/NV4500 conversion so my drivetrain is not stock and probably does not sit at the same angle as stock. (And I knew I would need to change driveline lengths anyway.) But the drivetrain and rear diff angles match almost exactly so no shims in the rear.
I needed 4 degree shims in the front to bring the castor back to spec. I have since had the truck on the alignment rack and my castor is +1.4 degrees. I am replacing the aluminum shims with custom steel shims at 5 degrees even though I track straight and true as is.
My shackle angles are a little too vertical but they may settle out some. Also, it wouldn't hurt to use 1" longer shackles in the rear if you run a hardtop with lots of tools and schtuff in the back.
So you should install the new suspension, then meaure diff angles, then decide how much shimming you will need. I almost guarantee you will need shims. HTH :)
I run a 4" TPI lift with stock length shackles. The kit came with 6 degree shims for the front so I used them. Driveline vibrations were still pretty bad so I also put in new u-joints since the old ones were worn in the factory position.
