Need slightly longer wheel studs
The part number for the toyota studs? I got it from another thread, but confirmed when I called the dealer to make sure what he pulled up was wheel studs. They didn't have them in stock, so I wasn't able to see first hand whether they were the right ones.
x2 on moroso
fj60 studs don't seem to be long enough, so I'm also going with 1/2" moroso studs (same kurl as stock).
MOR-46220 WHEEL STUDS 1/2-20 x 3"
SUM-7540026 ACORN 1/2" 4PK LUG NUTS
Planning on doing install when I do gear changes...a couple of weeks out.
Any updates on the Moroso studs? Did they work out ok?
I still need to do something about this. I have another set of wheels that seems marginally better, but I would rather install different studs than pay to have the wheels powder coated and mounting/balancing.
Thanks,
CAZ
SHort studs
There are non that I ever found. Best solution is to use a shanked lug nut that is able to fit the wheel. It will give you from 3/8" to 3/4" of additional reach. I got mine from a large chain tire store that handles a lot of mags.
lug nuts
you can get lug nuts with a longer shoulder below taper. thats what i used on my fj40 & it worked great, got them at my local tire store where i got the spacers
