Hi folks, I'm hoping I can get some help with this problem. I'm currently replacing both front bearings on my 01 Toyota Highlander 2wd because they finally gave up the ghost after 231k. I managed to remove the hub spindles and the inner bearing races from the spindles, but the outer bearing race will not budge from the knuckle housings.
I tried to use my 20 ton press and it still will not budge. It actually bent a part of my 20 ton press. I've tried spraying Kroil where the race makes contact with the housing and leaving it overnight to soak and still no go.
After doing some reading online. A few people have suggested welding a bead all the way around the inside of the outer race. The thought behind this is that the heat will make the bearing race expand, but after it cools it should fall right out?
Or using an oxy/acetyl torch(which I don't have) to heat the outside if the knuckle housing causing it to expand, then the race would fall out because its cooler than the housing?.
But, wouldn't both methods compromise the knuckle housings' hardness or temper?
I'm really trying to avoid forking out $600 for a pair of knuckle housing from the dealer.
I also tried going to an online wrecker, but they still have the bearings and spindle attached. In most cases, the mileage on the assemblies they are selling are over 150k. I don't know if the bearings will pop out of those as well.
Anyway, I'm running out of options and would really appreciate any help or suggestions.
Also here's some pictures of the offending part.
Tanks again for any help.
