According to the first picture he is measuring correctly, although the probes are reversed giving him a reading of -13.68 mA because he's measuring off the negative terminal.
It's possible that meter has internal current limiting to avoid blowing it up. I would simply take another reading with the probes reversed to be certain. If the reading is in the range of 20-30 mA of quiescent draw (everything off, doors closed) I would call that good. At that point you're just reading the clock, ECU, and radio.
IMO, a draw of over 30mA is something to be concerned with, depending on what other doo-dads you have installed.
If your battery is a typical flooded cell and it doesn't hold a charge, then it is already too late and you're not bringing it back.
There is a reason good batteries cost a little more.
