I just took my front springs off to replace with OME med/heavy kit. old springs had a caster shim. should i reuse that shim???
Thanks ahead of time
the springs had an ada leaf in them and then a heavy duty shackle looks to be and inch or so longer than stock, i dont have the original shackle so don't know for sure.They OME kit is supposed to work fine w/out a shim. The question is why was there are shim in your old springs? Were they stock, or aftermarket? Were longer shackles installed? Shims didn't come from the factory, so somebody added them.
From what I've read (I don't have a lift on yet, so no real experience with this), you only need shims when you go 4" lift or more. And then you'd need extended brake lines, and maybe some kind of steering rearrangement, depending on the lift.
sage advice. I will keep the shims just incase i may need them later.I am struggling with my alignment right now on my OME lifted rig. Recently, I added a 2 degree shim which seemed to help some. Most people seem to get along fine without shims on the standard OME upgrade but I would recommend that you hang onto the shim. For what its worth, shims come in all degrees of angle and you might measure yours to see what you have. Several people told be that a little increase is good with the lift so if you have thinner shims you might want to give them a try. Thicker shims can might cause installation problem if the bolt through the spring pack is not long enough to anchor the springs in the perch on the axle.
