Need help on 1fz heads
Rialto
So my lexo has a blown headgasket and i ended up pulling it off the other day and i took it to the machine shop the other day and they called me and let me know the the head has a couple of cracks in it. Fml so i did some searching for a another head and i found one but its a little different then mine here are the pics of both heads the one i found was cheap and it look almost brand new but it has no hole the egr whitch i dont mind cause ill just get rid of the egr but theres another hole thats opened and i have no clue what thats for but again i can block that off i just want to get a little more info on this head and see if i can use it...
Your cracked head appears to have much larger ports then the one with out egr
I just checked it with a caliper and on exhaust side they are 44mm on both heads and intake side there is about .3 .4 difference and yes the old head intake side is slightly bigger
Don't forget if you live in a state that does emission testing, you'll need to deal with the extra cost of drilling, and tapping, that new head to mount the EGR valve.
Looking at your old head. Are you sure those are cracks and not casting marks? Hard to tell from the pics ecspcially giving the picture. Also was that .3-.4 discrepancy in inch or millimeters? Cus if mm that wouldn't be noticable by eye
My head was cracked EXACTLY like yours. Side by side they'd look the same. That newish looking head is probably a Chinese part replacement. Have not heard a good thing about them
Done some research for my turbo build on getting a new head. The response was aftermarket heads from china are rubbish and to go with a genuine head. Not sure if the genuine head has some part numbers or markings on it?
If you go for an after market head the ones made in South America and South Africa were the ones to get.
I was looking at getting an Amada head from Precision International as they owed me a store credit but i have had a brand new head from them fail, was a 1HZ diesel.
Precision also have crap customer service.
Looks like an aussie spec head. Our heads have no egr and the other hole is for a manual fuel pump which is blocked with a plate.
Did they crack test your head or are the cracks visible by eye?
The cracks are visible by eye and there are 4 different cracks on it
It was measuerd in mm we checked it with vinear calipers and on the cracks im sure there not casting marks there is water stains that are not cleaning off
I was thinking the same thing about it being a china head and i dont really trust it and i dont feel to comfortable going through all the work to install it ill see if i can find an oem head but it is hard to find one.
There is a recent post here about making one of those work but it was by a member with access to machining and tooling equipment at a school lab i think. In the end impression was not worth it after hving to do lots of cleanup to the head in other areas as well.
Extra hole for the mech fuel pump like frankenyota mentions.... lines up with extra lobe on intake cam
Short of getting a new factory head (i found one for $1300). Getting one you source yourself from a junk yard would be the cheapest. I'd try to work a deal with the yard that if the head you pull is junk then you want your money back if the head doesn't check out of course. And I don't know what's included in the factory head. Could call the stealership and ask. Part number is 11101-69107
One thing concerning remanfactured heads...
I recently spoke with Slee offroad about an engine build and they informed me that a number of their recent head gasket jobs (machining block and head) have resulted in cracked heads. They informed me that they are getting away from doing this type of work unless new heads can be sourced directly from Toyota or an authorized distributor.
