need help new to off roading
So i have a 1994 Chevy k2500 lifted. i recently bought it and the person before me dropped from a 16 rim to a 15rim and then must have bent one of the 15 so he put the 16 spare on it well that s*** don't fly i have a 15 by 10 rim with no tier. and the other 3 tiers are 33 /12.50R15 i need to know if it will fit on the 15by10 rim ??? any help would be appreciated
If you are asking if a 33x12.50R15 will fit on a 15x10 rim, yes. Although you won't be able to air down as much as if you had an 8" wide wheel. If you are asking if the tire from the 16" spare will fit onto the 15" wheel, no. As the truck is a 2500 (3/4 ton) it should have 16" wheels due to the higher load capacity of the tires. Unloaded isn't an issue, but your K2500 has a higher GVWR than 15" tires can support. The rear axle should have a
GAWR of 4,800lbs, and most 15" tires have a max load of 2,200lbs.
