I've been having issues getting my 40 started for too long now and need help.
For background, the PO installed electronic fuel injection, a 3 wire alternator and a DUI HEI distributor from Performance Distributors. I also put in LED headlights a friend of mine gave me right before my problems started.
After starting right up for the first few months I owned it, I started having issues. On a few separate occasions, it would struggle but eventually fire up. I thought it was the alternator based on a voltage drop with the lights on, so replaced it.
It continued to struggle without firing so I turned to the distributor. After changing the ignition module, it fired right up and drove fine around town for the weekend (4 or 5 starts)...until it stalled pulling back into my driveway on day 2 and wouldn't start again. Assuming I was burning out modules, I purchased a couple of cheaper modules to allow me to trouble shoot. Neither of them worked.
I pulled the headlights and put everything back the way it was prior to the issues, with the exception of the alternator (which was traded in at the time of purchase). I purchased another module from performance distributors and it fired back up again without hesitation, but only ran about 30 min before dying.
I purchased another module from Perf Dist. (assuming the last one burnt up) but haven't gotten it started since. My voltage is starting at 12.5 and dropping to 11-11.4 volts. I've also checked the coils, tried a different battery and ran a temp jumper wire to make sure my hot wire didn't have a resistor I couldn't see.
At this point I'm thinking I got a bad alternator and changing it out again based on the voltage drops.
What else should I be doing/thinking about aside from wasting money?
I'll take any and all input, but I'm not a mechanic so please keep it simple enough for me to make sense of it.
Thanks
Tim
Thanks
Tim
