Need help for starter motor!!
Bologna, Italy
Website
www.fuoristrada.it
Hello everybody!
I have a big problem: the starter motor of my 1972 Fj 40 doesn't run anymore.
I brought it to a mechanic but he said that I con't manage to repair it.
These are some pics of actual condistions:
Here in Italy is very difficult to find a service starter for this car (here we have only BJ 40, with diesel engine); and if I find it in Toyota it will be surely very very expansive.
So, do you think I could find a used one overthere in USA and let it to be sent to me? Do you have some address or website where I can find it?:confused:
Francesco
Use very fine grit sandpaper and go after the copper contacts and magnets. Lubricate all bearings with axle grease (pack them if possible).
Check the brushes at the bottom of the second picture. They may need their springs stretched out. If the solenoid is ok, then you should be able to get this back into service until you find a replacement.
There are lots of places online that sell new or remanufactured starters. Have you checked with a Toyota dealer for a new one?
Yes I checked but the price is really to high (about 600 €).
The solenoid is surely gone becouse when I turned the key I couldn't even hear the classic "clack" of the solenoid opening.
I think that in tha USA prices are much lower and, inluding shipping, it would cost muche less then here in Italy.
I'll check on the net trying to find some sellers of this part; does anybody know where I can find it?
Francesco
Francesco,
You should be able to find one here on MUD. Check the For Sale-Parts section and post to the Wanted-Parts section.
They are also available from CruiserParts.net for $20.
http://www.cruiserparts.net/parts/fj40.htm
I don't have a clue what shipping would be, but they are fairly heavy. Still, it should be much cheaper than 600 Euro.
Good Luck.
Francesco- you are much better of with a starter from an FJ60 engine.
It is a smaller, lighter gear reduction unit that uses less current and turns the motor much faster.
If you source one from the US, get one of these starters. I swapped my old starter out for one, made a world of difference.
Can you use the FJ60 starter on an F engine?
It looks like I would give it a good cleaning before I give up on it. Remove any dirt and grease with a soft brush and a degreaser Dirt will cause the starter to short out when moisture is present and the dirt will act as an abrasive so clean it good. If the amarture is worn unevenly by the brushes put it on the drill press and use a small file and file it down as it rotates( the first pic, bottom of pic). If not use some sand paper and lightly sand it.
If it were a 2f I would recomend getting a newer starter which came out in the 80's, it has more torque and uses less current. Check the diesel section, they may be able to steer you in the right direction on this.
