All, I started to remove my exhaust on my 1FZ from the manifold back. Everything was going pretty smooth until I started to remove the down pipes from the manifold. I got all of the lock nuts off except for one. I ended up rounding off the lock nut and was pretty much screwed. After sprinkling it with fairy dust and a day later I finally ended up getting the entire manifold stud to break loose and come out with the lock nut still baked on. I took a dremil tool and cut off the lock nut but I slightly damaged the threads on the stud. Does anyone one know the size of the stud? I have a tap and dye set and I was going to try and fix the threads.
Thanks.
Thanks.
