Need help diagnosing bad idle.
Alright, so here it is. 94' cruiser Fzj80 with 4.5 liter. A few months ago it started idling bad and has gotten worse. I replaced MAF sensor, since I had fixed the original one two years ago and thought my soldering might have come loose. New fuel filter and sock for pump. Relatively new wires and plugs. Anyways the truck runs great once you going, but has a real low, uneven idle and will eventually sputter and die. Last night I was messing around with it and as a I pinched this hose it would idle better. So I zip tied some pliers on it, not completely pinched off. Like this, it idles almost perfect. I just don't know
what to do from here. Thank you in advance for your help.
Check the air intake tube for any cracks. Also check your PCV valve and grommet, you have lots of oil in that area.
Thanks for your reply MLX450.
Yep my motor is in need of a cleaning. But I've taken off the air intake tube, and there are no cracks in it. Before I put the new mAF sensor on it was throwing the code for it. But after I put on the new MAF I pulled the EFi relay and the code cleared and has stayed off, no CEL or codes now. The Pcv valve appears good, as well as the grommet. checked and not find a leak in or around any vacuum lines. I'm not sure exactly how the vacuum system works, but here's what I found.
If you pull the PCV valve out of the valve cover while the engine is running and put your finger on the end it's sucking air pretty good, and pulling it out causes the idle to go from bad to very bad.
On the other vacuum line from valve cover to throttle body, if you pull the end off the Valve cover while the engine is running, there is no noticeable suction or the opposite. And no change in engine performance.
Not sure if this is normal. I really need help on this, I've done every thing I
Know how to do. Thanks guys.
Poor idle is almost always caused by unmetered air entering the system. When you removed the PCV valve, you opened up a hole in the top half of the motor allowing unmetered air in. The same thing would happen if you loosened your oil fill cap, pulled your dipstick, etc. All of these things have gaskets that seal the top half of the motor to prevent vacuum leaks.
If she runs smooth as soon as it comes off idle, then you have a vacuum leak.
You said, "A few months ago it started idling bad and has gotten worse". What was the series of events prior to the poor idle?
Do you have a CEL? Check if the bulb is burnt out. Does it light up at the ignition before starting? Have it scanned for codes.
First thing you need to do is get a set of vise grip needle nose pliers,.
Sticky tape all over my pliers would have me angry, but to each their own.
It started periodically idling rough out of nowhere. Then after a couple of weeks I was driving and it overheated (be cause of low coolant / small leak in radiator ) for just a short time. Then it seemed to idle even worse. That's when I put the new Maf on. Better idle , but not good.
Yes I do have the CEL light. It works and was on for the old maf sensor, but cleared when I reset it after I put the new maf on.
Question: does the diagnostic store the previous code even if the light is not on? Because the light will flash on for a couple of seconds then goes away. If I check the codes will it show me the most recent?
Question 2: Could a bad radiator cap be causing this problem. The day it overheated , the seal on the cap got fried a little and probably isn't pressurizing the radiator. I'm going to get a new one today.
Only go with and OEM Radiator cap if possible. The aftermarket ones tend to not seal right. An overheat I don't think would have "fried" the radiator cap, but a bad cap could cause an overheat.
No, it does not store a code after the codes have been cleared, BUT, it MAY show "pending" codes, although yours is OBD1, and may not have that option (I'm not sure).
How much have you started / driven / turned it on/off since the code clearing? Sometimes if you have cleared the codes and unhooked the battery, it may take 20 starts/stops to re-learn settings and that may be a cause for poor operating condition.
