Need Help, bad clunking!!!!
Manitoba, Canada
I have a 1991 Fj80 that makes a really bad "clunking" noise when you put it in reverse or drive. Along with the clunking noise there is also a metal on metal "ping" noise. It seems like the noise is coming from the trasfercase. (i took the front driveshaft off and there was no clunking at all) Also the driveflanges have been replaced and the U-joints appear to be in good condition. There is about 1/3 of a turn of "play" in the front driveshaft though. Does anyone know what the problem could be?? Thanks in advance!!!
I tore into my drive shafts this past weekend. I had very little play in drive shaft after disconnecting from the transfer case. No doubt your clunk is due to the drive shaft taking up the play in your axle.
I've heard that the clunk noise is just play in the driveshaft/drivetrain, can't remember which one. I've also heard it's not a bad noise, it just shouldn't get any worse. Don't listen to me though.
I hear a lot of things that aren't actually said....
fwiw, mine does the same...no issues according to the dealer
same issue in my 95 with 117k. Only when shifting from reverse to forward or back. I don't think its an issue.
i am planning on selling it though and the clunking isnt really a good selling feature lol. How do you fix the clunking noise??? Thanks again!!
I've had it since I first got my rig two years ago. Everything feels really tight on mine, so I think everything is fine.
I now pause for just a second in neutral when going either way between R and D, and it doesn't do it at all anymore. I have completely forgot it was there.
-Eddie
Fix?? :confused:
91-92 Cruisers are notorious for the infamous clunk. There really isn't a way to fix it.
Like mason said, hold it in Neutral for a second or two before switching. It should help.
