Moving the actuator rod at the LSB&PV helps to bleed it.
I dont have the luxury of not driving it and flatbedding it anywhere.
If your rear brakes are only letting out a little fluid, it could be that you need to disconnect the rod from the rear axle for the LSPV and move it UP to open the valve to allow more flow out the rear. I made this mistake on mine and never bled it properly. Take it loose at the axle and move the rod UP. Some people disconnect it entirely and wire it to the bottom of the body to keep it full open all the time. Not the best, but it will help.
