Okay, here goes:
What does your meter read with the ignition on, but without the engine running?
It deflects just to the negative without the engine running and the ignition turned on.
Do you have ANY accessories attached to the + post of your battery?
Not on the battery itself, but as Pin Head pointed out, there could be something attached on the battery side of the ammeter. A long time ago (20 + years ago, long before it was mine) there was a radio and a CB installed in this rig. Maybe they were attached on the battery side. Or, maybe when they took these out, they screwed something up. I'll go through the wiring and find where they attached them.
I wasn't sure what you meant by reading + 15A after starting it, but if it never drops to zero amps, then it indicates 2 possibilities:
1) the battery is bad and never fully accepts a charge.
2) Somebody installed an electrical circuit on the battery side of the amp meter. In the stock wiring the battery is the only thing on the + side of the amp meter, so that it only reads current in and out of the battery.
1. The battery was bad, so I installed a new one a few days ago. I think Mr MoMo hit it when he said that it would burn up a battery if it was always charging. That battery was only about a year old. But, after putting in a new battery it still does the same thing.
2. As I said above, there used to be a radio and a cb in this rig. They could have been installed on the + side of the ammeter. If so, when they were taken out, they could have messed something up. Thanks for bringing it up, because it was somthing that I had forgotten about. I'll definitely look into it.
It deflects negative current when you turn the lights on because either the alternator isn't putting our power ( which is why I asked you to test it in the truck) or it is wired incorrectly directly to the battery or wrong side of the amp meter.
The alternator is new, so it should be working. I should have listened to you before. But, it was a 35 year old alternator, and for $50 I got a new one. The wiring looks stock going to the alternator. However, as I said before, there is no wire going to the N terminal. Is there supposed to be? The ammeter is hooked up properly since with the engine off, if I turn on the lights, the ammeter deflects to negative.
I'll look into the old radio and cb wiring and see if there is something causing problems. Thanks again for the suggestions.
