Need Bypass hose
What you need is to replace the transfer case input seal. If not fully rebuilding the transfer case it can be done in a few hours.
Would that be the time if you don't have a lift? Unfortunately the split transfer case requires a lot more work to remove it from the transmission. Assembly of the split transfer case is a lot harder when you laying on the ground under the cruiser. Especially if you are not a mechanic who does it for a living.
There are a few well known mechanics that put these bypass hoses on every Landcruiser that goes through their shops. Owners aren't always aware to check the oil in the transmission and peobably don't know what is happening when oil comes out of the fill plug. They install these as insurance they don't drive their transfer cases dry of needed oil. Thants the kind of mechanic you want working on your rigs.
