need brake help
Help please! This is my first post to this forum. I have four wheel discs on my 74 fj40 and they suck right now. In fact almost killed me one the trail because of their in ability to hold on an incline when the engine stalled. I have the MAF rear monte carlo kit with the 92 4runner calipers up front, stock dual diaphram booster with the MAF 4wd master (I believe it's for a 80 series non abs), all braided steel lines, adjustable prop valve to the rear. Everything is bled. It is as if the fronts are not gripping very well at all. The rears seem fine good even wear pattern the fronts look as though they are not fully seating on the discs there is a 1/4" light rust band on the outer edge of the rotors as if the pads are not completely flat on the rotors. Has anyone run these 4runner calipers with this set up and had this problem. The pedal is firm and is a good distance away from the floor when pushed but it just wont stop the vehicle very well. At a dead stop with the engine off on an incline the brakes should hold the vehicle but it doesn't. Thanks for reading this any help is appreciated.
Welcome.
Is this something that has just started?
How long ago did you do the conversion?
Sounds to me like you are not getting any fluid flow to the fronts, could a steel line be kinked or damaged someplace, or even a flex line?
Bleeding the front brakes...
Do you open the bleeder screw and watch the fluid flow out? If so, every time the pedal is depressed do you get a good stream of fluid?
Good luck!
-Steve
I am getting good fluid to all the caliper with no kinked lines. I am concerned that the larger 4runner calipers are a volume issue but i thought the 80 series masters could handle them. anyone out there running 4runner calipers if so exactly what master are you using ?
The conversion has about 500 miles on it and I thought they would get better with time but no dice . I've since driven a couple other cruisers and they all stop on a dime by comparison even one with stock brakes. Could it be the diaphram I'm hesitant to think this because it won't even hold on a incline with the motor off.
If it doesn't stop well with the power brake booster, then it sounds like the M/C isn't developing enough pressure to create the necessary clamping force.
I would start by making sure which master cylinder you actually have.
If you can't tell the difference with and without the booster connected, then you have a booster problem too. It should be considerably harder pedal pressure without the boost, but it should still stop well.
I have the same set up as you describe on my 08/75 but with 76+ FJ40 booster & MC and do not have the problems you describe. May I suggest you measure the brake fluid pressure at the calipers and the MC. Should be equal and in the 1200- 1500 psi range. You can buy this from SSB or I'll sell you mine for $50. Second, make sure you don't have a piston(s) siezed in the caplipers. Either take them apart and inspect or retract the pistons using a big screwdriver. I have personally experienced this with new $200+ Willwood calipers as part of the MAF FDB kit.
Good luck and let us know what you find out.
Thanks for the input. I wil measure the line pressures thanks for the expected values. I suspect that it is either the mc or the calipers (new from autozone but that doesn't mean anything) since it doesn't even hold at a dead stop w/o the engine on. Although the booster will be my third suspect. Does anyone know if the MAF mc for a 95-97 w/ abs (this is what I have I checked) is supposedto work with my setup? Thanks again!
tfdcruiser said:
Does anyone know if the MAF mc for a 95-97 w/ abs (this is what I have I checked) is supposedto work with my setup? QUOTE]
You might want to call JT Outfitters and talk with Joe Turpin (sp?). I know he sells a mastercyclinder for this set up and I think it's from an 80-series. See
http://jtoutfitters.com/product/RDBMASTER
Some have strong opinions on JTO but he has been very helfull to me and I have found his stuff is what he claims it to be, not like some other vendors.
tfd------I had the same problem with my '74 after I put 4 wheel discs on, after replacing afew M/C and diaphragms, I put in a mid 80's Cadillac diaphragm and M/C. it is 8" dia x 6" deep, the M/C is rectangular shaped, about 6" x 3", this will lock up my 36" Super Swampers, it was the best thing i did with the brakes...........oh, another thing, I had to mount it to the firwall with a plate and I had to do a little welding on the pushrod to the brake pedal arm...........good luck, I could send pics if you want.
