Anybody have a pic of a fish scale that I can use as reference (for setting the torque on wheel bearings)....Front Axle Rebuild....I want to make sure I buy the right one..
I called around and they range from cheapo $10 to fancy $100+
Get a spring scale from Harbor Freight if you have one close. ~$5 if you find it. I'll try to find a pic.
Hmmm. Seems they don't have it on their web site but you might check your local store if it is close by. You'll find it in the kitchen section. The scale is 0-55lbs with a kg scale too. It is similar to this one with a smaller scale and a smaller size.
The small one has a T-handle at the top with an open hook on the end of the spring. It also has a small loop on the top. The scale is black anodized aluminum with a blue anodized T-handle. HTH.
