need 411
HI 2 WA
Heres the run down. I have a 91 LC. The parts that i have is a pair of front OME comp 4" coils. The rear is a pair OME J 863 coils. I have the caster correction yellow bushings. All front, rear, and steering shocks from OME. All from ARB.
I just wanted to know what else i need to complete my lift. I don't want to start it and then find out i i'm missing something. All 411 is greatly appreciated. Mahalo and Aloha, Dain
With the OME yellow CC correction bushings I think you will still be out of spec. Also with a 3, 3+" lift you may come into DC vibs.
anybody else running this setup?
anybody?
depending on the weight of your vehicle... plan on some additional caster correction and adjustable panhard rods to re-center your axles. longer brake lines. maybe new drive shafts with double cardans and upper control arms to reduce drive line vibes
Thank you very much. More would be good too.
Pick up the blue castor bushes from sleeoffroad.com. Get the template from Rick here on the forum. Driveline vibrations are still possible, but it depends on the condition of your driveline.
When you ask for information it would help to know what your intended use is.
