- Thread starter
- #21
roofrack powdercoated. done.
And the 265/75R16 on the front and 305's on the rear.
We'll be wearing out the 305's. The 265's look like a donut spare with this lift.
I also swapped in a LC console. Love the extra space inside and the cubby to hold stuff!Well, I took out the Lexus center console and sub-woofer (or you can call it that) and replaced it with the center console from Dead-Ed. I like the little bit of extra storage it offers.
I thought I fixed the PS front seat. When unbolted it moves forward and back freely. When I bolted it back in it froze up again. Will look at it again next week.
Running significantly different tire diameters will mess with your ABS and put extra wear on the Viscous Coupling. I would not recommend doing this.
Re: Seat issue: It sounds like the mounts from seat tracks to the screws are not matched up properly. When it is unbolted, the frame flexes enough to allow them to move in synch but when you bolt it down it squares the frame and puts the screws in a bind. If you move them very much while out of sync you will strip the little plastic gear. Make sure the distance from edge of plate on screws to end of screw shaft is the same on both sides. Gamiviti is the best place to get replacement gears. HTH!
