Name that missing part (3FE)
Grand Lake, OK
Did anything go here? There is an empty connector, and a broken plastic bracket behind it.
I also discovered the entire o2 sensor is missing (the inner most o2 sensor). So that sucks, wire and all.
What year? I can't stand a rabbit hole I haven't run down...
Pretty sure my 3FE is missing whatever those plug into also. I want to say its for something that was on the foreign markets and not the US.
Yeah @inkpot my check engine light is on, flashing code 28. Which is o2. I thought I’d have a look at the condition of it and when I stuck my hand under there I could only feel the spot where it is supposed to be seated.
About the plug, I feel solace in the fact that other people are missing it too.
@Malleus its a ‘91.
I’m following jonhelds, tune up guide. I’ve replaced everything on the list except for the EGR. I don’t know whether to replace that or cap everything off. But I suppose that is another thread.
Is there a number on the housing?
The 60s and 62s had this, but I can't remember seeing an 80 with one:
If it's the fan motor, the wires should be gray and white w/ black tracer. Since you don't have it, you won't have the relay either. Unless someone sold it, you know like a third world kidney donation?
The cooling fan motor sits next to the radiator on the 3FE same location as the stock battery on the 1FZ our battery is opposite. I will have to take a look but I one is probably for the headlight washers (I have them so I will look this afternoon)
my 92 is also missing the exact same thing in the exact same place, no CEL though. so i just decided to ignore it since it's not causing any issues
