mystery engine vibration... psychics needed!
e9999
Gotta get out there...
Moderator
US
OK, I don't even know how to begin this.
Ooops, I just did... WTH?
Anyway, here goes:
I have this funny subconscious feeling or is it intuition (am I becoming more mechanically savvy after reading 15000 posts here?) but I find my engine to be running in a sorta vibrating way both at idle and when going. Can't quite explain it but it's not silky smooth. Not a strong vibration but feels sorta rough, kinda like the difference between dragging a brick on pavement vs an aluminum pan... No weird noise but "feels" rougher than the V8 on the 100. No ups and downs in RPM or anything like that, just feels harsh, yea, harsh, that's a better way to describe it than rough.
Anybody else?
What is this?
(FWIW, no indication that it has ever had a tune up by PO if that would make any difference...)
How's the power? Think you might have some bad wires next to the EGR? How about a bad plug or wires? Rotor and cap? What you're describing sounds like a missing engine. Bad gas and/or dirty TB?
power is great. Don't know if it's even abnormal, could be OK. Just harsh...
Need to drive another one to tell.
Don't think it's missing. RPM constant around 700 or so at idle, no "missing" sound, just a tad noisy and harsh...
Told ya, can't explain it.... :o
(am I becoming a psychic myself, or is this extrasensorial cruiser perception developing?)
Anyway, anybody else "feels" the same way or is it just me ...?
is this just a "harsh" engine, beloved as it may be here?
Yer arse is getting spoiled from the 100 :flipoff2:
Eric,
Are you talking about the vibration that's merely enough to tell you that the engine is running; as opposed to the glassy smooth of those V8s where you can't even tell if the engine's running or not?
acolella said:
It may be as simple as a rattling EXHAUST sheild. Is the sound coming from passenger side of motor? If it is then thats my guess.
not rattling, harshness...
sjcruiser said:
Eric,
some of that but a bit more than just running.... running a tad harsh....
landtank said:
Eric, I'm getting the idea that the engine might be running a little harsh.
If you don't know the age of the ignition stuff I'd replace it since it was do at 60k.
did I say I think it's running a bit harsh? :D :D
hmmm... how much $$ are we talking about for a full tuneup kit, and would it make any difference to harshness at this mileage?
does everybody agree that the 80 is not normally running as smooth as the 100?
(ayeeee....! don't let Shotts see this...)
This thread taps into one of my many mini-obsessions about my new beloved 95 FZJ 80. I recently purchased from oo with about 88K miles, thorough maintanence records were included. It ran smooth when I first bought it, but I wouldn't quite call it silky.
Two weeks ago I replaced the plugs, wires, cap and rotor, and faulty EGR modulator. Noticeable gains included smoother idling, smoother running, much increased acceleration, and about +2 mpg.
It did not however, get rid of light vibration felt when placed into D or R while idling, it perhaps is slightly improved. This vibration does seem to go along with a slight "harshness" from the engine. The vibration is significantly less noticeable once accelerating. Overall, the engine does run very smooth. The vibration is not enough to be felt on the dash, but it comes strongly through the High Low shifter.
I've read through the threads on HL shifter vibration, and mine does not even compare to those descriptions. However, I have wondered if there is a connection between what is causing mine to vibrate and those more severe cases.
I too wonder if this is a very common issue (or non-issue) with other TLC owners out there. Maybe its just the nature of the beast???
Perk
I have been struggling with this very issue for a few weeks now!
mine i think has alot to do with the sliders and lift that i have installed on the ride. I have been trying to figure out what exactly is the culprit that causes the vibration as well as a few noises that i dont like. it is going to take a few weeks it looks like to try the different elements in order to see where the problem is coming from. i am going to do a full tune up in this time frame already have gottent the parts to do from cdan thanks!
Perk
Funny, I also just bought a 95 FZJ80 w/ factory lockers 02/05/05 w/ 72K w/ very detailed service records from new at Toyota (it was a no brainer buy) and love it. Thinking of switching to Amsoil 10w30 w/ dual filteration sys. Anyway, my previous owner complained w/ the same rattling problem and Toyota diagnosed it w/ a rattling exhaust sheild(s). Check them out it may be as simple as that. The only problems my truck has right now as far as I can see now is (1) the drivers door key auto lock feature does not work but does on the passenger side. (2) little rust at the running boards (2) the "D" drive does not light on the dash. (3) The floor by the dead pedal is damp, probably from a leaky sunroof. (4) drivers leatherseat is a little worn/ cracked. (5) scratched bumper(s) otherwise its a bullet proof truck and few rival it including the 100 series.
THis thread is perfectly timed. My 95 is also running a little rough. I agree, i think new plugwires and cap will solve much of that. But, i also found that i had a small crack on the intake (air hose running from air filter can to throttle body). I temp. fixed it by removing it and wrapping duct tape on it for now. But after patching the crack i noticed a much smoother idle.
Can O' Worms is opened!
I think I know what yer experiencing...I describe it as a slight "shudder" or "tremble" at idle (800-1000) - not noticable underway or accelerating - otherwise smooth and good power for an 80 :D Yesterday, I had a visit with my neighborhood Toyota shop and had them do an injector cleaning (EFI), change out the plugs and reset to factory specs. The mechanic thinks the wires (not cheap but good stuff), cap and rotor are in great shape and leave them alone for another 50k or until I start running on 5 cyls....I did have the CHECK ENGINE light on - now off after yesterdays service but I'm sure it will come back. I'm guessing it's EGR related? I only run Chevron gas and regularly use Techron but while good, only goes so far. I'm actively seeking to remedy this minor annoyance and will report back. Let us know your results....curioser and curioser.
This is the first thing that I noticed after getting into a FZJ80. The couple that I've driven, has this similar "vibrations" feeling. I describe it as if you're driving a manual transmission vehicle in the wrong gear - sort of a "lugging" the engine type of a vibe. By no means, is this engine as smooth as my other six or an eight but you can't beat the torque!
This is what I'd do for a truck with a slight rough idle:
Tuneup if needed
clean throttle body
clean fuel pump relay
check for cracks in inlet tube from air filter canister to throttle body
on 95+ check for a crack in the exhaust where it Ys to the 2 manifolds, a small leak screws with the O2 sensors big time
