Mysterious Brake Light question
Dallas TX
my driver side rear brake light will not light up. First, I thought it was the bulb...oh no.
When I plug a new bulb in, the center brake light came on constant. But when I removed the new bulb it turn off.
When I had the old bulb on, the center brake light stay on. Most drivers thought I was nut due to constant rear center brake light on, they would honk....I'm an idiot or something.
I check the fuse, ok. The new bulb same spec as OEM. But I plug it in, heard a click under the dash and rear center brake light stay on constant.
Now I took out the side brake light so the whole thing will not stay on.:confused:
Have you taken a voltmeter to make sure there is voltage there?
If there isn't any voltage, I would take the brake light assembly out (Just a few screws and check the voltage at the connecytor and inspect the wiring.
Report back and we will go from there.
