My White Collector’s Edition Build Thread (kinda)
MScruiser
obsessive-compulsive oppositional-defiant wise-ass
Jackson, MS
Because @G-Cat keeps hassling me, I’ll start a thread to document what I do.
It’s a 1997 factory e-locked White (045) Collector’s Edition with Oak (tan) interior.
First, this truck was originally sold in Arizona, and spent nearly its whole life there. After two owners in AZ, it was purchased by the PO, who lives in North Carolina. He had it a relatively short time (a year or so). He had spent several years looking for a clean white Collector’s Edition, when he found it. He had several other cruisers, and with the recent purchase of a 40 series, his wife told him one of them had to go.
It’s clean. Like really REALLY clean. Zero rust. Interior is pristine, besides a worn steering wheel and shifter. Front seats look to have been recovered, and DS floormat has a wear spot. No other stains, rips, tears, odors. Nothing.
Carfax shows 4 pages of complete maintenance history. Lots and lots of preventative and regular maintenance. No red flags.
Underside is rust free. Not a drop of oil, fluids, grease, ANYWHERE. Amazing. RTV is present on all seals with new gaskets, so safe to assume all potential leak points have been serviced. New radiator and hoses, new heater valve, EGR is heat wrapped. Everything is done.
Truck has 200k miles. Engine runs smoothly with no drivetrain noise. Shifts smoothly. Brakes smoothly.
No real plans for this truck. I want to fix all the little things that aren’t working properly, and want to replace/restore things to bring it back to its former glory.
I do want to get a lift on it; nothing big—maybe 2-3 inches, and some larger tires (34”-35”).
I realize that 80 series are increasing in value, and I am also aware that the closer to stock they are, the more value they retain. Therefore, any mod I do, I plan on making sure it can be reversed. No drilling, cutting, grinding, etc.
Here are a few pics of it in my driveway.
Here’s a small checklist I made to keep track of what needs to be done:
First, I tackled the floppy/broken driver’s side air vents.
Done
Awww s***tttttt.
Weathertech mod. Boom.
Also: CARSEAT MOD 2X
CDL install and 7-pin mod to wiring harness.
OEM cupholder mod. Hells yeah.
There was a very small dent in driver’s side of the rear bumper. I am currently in the process of repainting it.
So far I have also:
1. Fixed the droopy passenger’s side sun visor.
2. Refinished the fender/flare gaskets
3. Refinished center caps
4. Cleaned a few stains off the headliner
5. Clay bar’d the exterior
6. Detailed engine bay
7. Detailed interior
8. Replaced passenger’s side brake light and side indicator lights.
Looks awesome - can't wait to see the evolution.
Initial thoughts on the 80 Series: (keep in mind this is my first 80, and I am coming from a 200 Series)
I effing love it. I could see myself driving an 80 series indefinitely. I love the ease of fixing things; reminds me of working on my 40 Series. No stupid computers to fool with. It’s an analog truck living in a digital age. It’s awesone.
Is it running 100 Series brake pads in the front? Easy "mod" you'll want to add when you increase tire size. Thanks for the thread!
Installed a new electrical diode in the driver’s side master switch. The diode enables the driver’s side window to have an “auto up” function in addition to the factory “auto down” function. The diodes can be purchased from many different retailers, but I bought mine from @LandCruiserPhil
Start by removing the switch module from the DS door.
Remove white/translucent plastic cover to access the circuit board. The two pins I’ve circled are heated with a soldering iron, to remove the solder.
Trim the leads to the diode.
