My rear wiper doesn't work
Check the fuses for the wiper units. I assume that you have already done that.
Check the grounding of the door that has the wiper mounted on it. I ran an extra lead to improve the ground and now my rear door wiper goes again.
Good Luck
The motor is easily removed, so remove it, clean it up inside, add some fresh grease to the gearing and then power it up.
You may want to seperate the gearing from the motor if corroded or dry.
Did mine a year ago and there were signs of rust and corrosion probably related to the salting of our roads.
check wiring through upper left of hatch (from hatch to body of truck through rubber tube). I had a worn ground that took out the wiper. I patched the wire and yabba dabba doo - I got rear wiper again.....
Problem fix, it was the fuse. The org fuse was not bad, but I replaced it anyway, then the rear wiper started to work. Another question, how come the front wiper works find during the whole time?
