- Joined
- Apr 24, 2003
- Threads
- 208
- Messages
- 2,210
Fj40, rear springs are stuffed.
grafting on fj55 rear springs, 3.5 inches longer (eye of the spring to spring perch is where teh extra length is)
measured up, if i move my axle back3.5 inches, diff pumpkin will hit the gas tank.
so,
there are 3 bolts/ rivets on the bottom of the chassis rails, which hold on the solid spring mount (not shackle mount) 1.5 inches apart, so if i remove these rivets, make the further most hole on the spring hanger line up with the middle hole in the chassis, redrill the front hole, effectively moving the spring mount 1.5 inches forward.
this only moves the axle back 2 inches once the 55 series springs go in.
this will clear gas tank.
rear shackles are vertical now, so the 2 inches further back will make them out to about45 degrees, so no prob there. no problem trimming the guards behind the wheel. the trimming in front of the wheel may allow for 35's once the axle is moved back 2 inches.
the front driveshaft on the 55 series is 1.5 inches longer than the rear shaft already in the rear of the 40, so i could use that untill i get my other one retubed/ lengthened, and the slip joint in the middle of the shaft should be able to cope with the extra .5 inch length.
bolting the front spring hangers on with strong bolts. i have read alot of US sites, SAE grade 8 sounds like the go, do we have the same bolt ratings?, if not, what is our equivelent bolt strength, so i know what to ask for at the bolt place.
new bushings, spring pins, u bolts etc is a given.
the spring clamps were buggered during the pulling apart of the springs, the plan is to get 4 mill thick box section, 75mm x 75mm, cut the top off it, making a U shape, to use to locate the spring (stop it splaying sideways). a hole will be drilled at the top of this, and a bolt/ pin used to limit spring separation onroad.
exaust should clear, if not, i'll cut it off behind the muffler, and have it exit into the wheel wells, or move the mount in a bit, it'll clear.
anything i have forgotten, this is my only car/ DD so i really want to plan for most eventualities, and this is the first time i am doing anything more than putting part A where part A should go.
will be away for a couple of days, so don't think i'm being rude by not answering...
so,
