My "new" beadlock wheels...
Carolina Beach NC
After Stephen caught my bead release last year, I'd been on a quest to find some "reasonable" beadlock wheels. Yet, I couldn't justify spending $400 a wheel for something decent nor could I justify spending $300 for some crap beadlocks.
So, I found some FJ80 steel wheels that I bought off this board (nice find, 5 for $200), picked up the beadlock rings (~$300) from Stan (Thetoyoutfitters.net) and got busy. Well, not busy, got working slow but sure. This will make the total cost of the wheel ~$100 each, more to my liking.
The wheels were in great shape with a "double" powdercoating on them. They had few nicks and I couldn't justify getting rid of the nice coating. I also debated keeping them black or going old school with white wheels. Kind of tough decision.
So, let the pics begin...
Nice, shiny start, probably should have left them alone but oh well...
Taped and scuffed with a 3M pad, ready for base paint...
The beadlock rings to be welded onto the wheels...
I found a few holes had to be cleared. They are cut with on a plasma table and it left a little "tab" where it started and stopped. All it took was running a 3/8" drill bit through them to clear. Not a big deal, just something to be aware of before assembly, it will save time down the road...
After clearing and sandblasting...
My home made turntable. Stan suggested finding a hub to put the wheel on to make welding easier. Thankfully, I still had a 40 hub/spindle from when we did the front disc swap last year on the 40. Made it really easy to drop the wheel on and spin it around to spread the heat during the welding process...
With all I'd read before deciding to do this, one issue is that the rings can "cone" when being tightened/torqued to spec (10-20 ft/lbs). I saw a few others had installed an "anti-coning ring" on the inside of the beadlock ring. This way, when torqued, it will put pressure on the ring and transfer additional pressure onto the bead side of the ring, not toward the center of the wheel. I just used 1/8 X 1/2" stock steel from the local "big box" store since its relatively cheap and easy to work with...
I did the first one by hand, then used it as a guide to pre-bend the next piece. Made it much easier on the following rings...
Getting ready to do the real work. Clamping the rings on so I can tack it into place...
I bevelled the ring and wheel to have a nice, clean surface to weld into...
Tacky, tack, tack...
part II to come...
Part II...
Time to burn some metal...
I wanted to be sure that I had solid welds and no pin-holes and thinking it should be easier to slip the inner bead over a smooth surface, I elected to grind the welds. Took about 30 minutes each to make them nice and smooth...
End results, not bad IMHO...
Now, just to find a set of 37's to go with them...:hhmm:
Came out real nice. As usual from your garage.
Jerry thats awesome looking glad you went with the white and black. Very nice.
Thanks guys, I appreciate it.
On a related note, I searched the NCDMV and Chapter 20 of the NC vehicle code and couldn't find anything on what to expect at the vehicle inspection if I have these on the FJC. All I've found is the discussion board "opinions" of legality of them but nothing concrete....
Jerry,
Keep a set of 6 lug wheels and tires around. Unless you know someone they will send you home to change the tires out, just plan on doing this once a year at inspection time. One of my quarry salesman has had to do this on his J#$P the last 3 years....
Jerry,
Thats the plan.
It just that I can't find anything in the vehicle code that says its "against the law"...
Very nice Jerry! They look awesome and you know they will be very unique.
Jerry that looks amazing! :eek:
Very nice looking work! What tires are you going to go with?
It's my understanding that the wheels must be DOT approved, I think it's stamped on them somewhere. Your wheels are DOT approved, they came from the factory on a vehicle. You have just modified them!
Do the inspectors around there go into that much detail when inspecting vehicles? Most people that don't follow our hobby can't tell the difference in real beadlocks and fake ones.
Looking forward to seeing them on the Cruiser!
Thanks...
Those look real, real nice. Can't wait to see them on the FJC.
I can't wait either. Just trying to find the right tire...
Sweet!!! Why did you take the anticoning rings off? Is it just the initial torqueing of the wheels that cones them? Thanks to the aftermarket fake beadlocks I highly doubt anyone gets pulled over these days even if it is illegal.
They are still there, just put the outer ring on top for the pics...
Still not sure what tires to get. Initially, I'll probably just swap the SSR's I'm running now onto the wheels. But, my first choice would be some Michelin XZL's in 9.00R16 (36.5 X 10) but I can't find a set anywhere. I can get a container filled with them shipped from Europe but I don't think I can use 15 sets of them nor do I have the cash flow to make that happen.
I've convinced myself I can do some "light" body work to get a 37 to fit into the wheel wells. I have ~ 1.5" on the rear wheel well that I can move inboard w/o any issues with the interior. That is the spot I get some rubbing now.
But, before I buy anything, I'd like to borrow a tire/wheel with a 37 X 12.5 to see if its reasonable to think it could be done.
When it comes to the inspections, I'm still lost as to finding anything that says they are to even be inspected. The "hit list" does not have wheels on it and, after reading through countless internet opinions, "bounty awards" and some legal info, I don't see how one could refuse the "legality" of them. I guess I'll find out...
If they refuse it will just be some sort of "safety" violation. The issue with "most" beadlocks that you buy off the shelf is they do NOT have the DOT stamp.
Since these are made by Toyota - I would look for the DOT stamp? If the stamp is on there (possibly inside) then I would "highlight" that stamp with 2 colors of paint so you can easily read it. And/or anything that mentions built by Toyota, other similar markers on the inside, etc.)
By "inside" I mean the part of the rim facing the inside of the truck, not underneath the tire.
Then if there is any question, you simply point to the DOT stamp of approval!! There is 1-2 mfg of beadlocks that DO have the DOT stamp so it is not impossible or anything.
They look nice, not sure though about the white instead of the matching yellow from the FJ? Might be too much yellow tho...
Great writeup - honestly this should be an article in the TLCA mag!
I spoke with my inspection garage about passing inspection with bead lock wheels. They told me that to their knowledge they are not illegal and would not fail my rig if I had them on at the time of inspection. I have not installed bead locks and had it inspected so this is not "first hand" information.
