Trade MY FJ60 for YOUR FJ40
Charleston SC
August 1984 FJ60 in medium blue - Mileage: 185,xxx
This 60 was bought from a broker who had sourced this cruiser from the original owner. I am the 2nd owner to have ever registered this cruiser. This cruiser spent 99% of it's life in Washington state, With it having zero rust! Now it's home is Charleston SC. The original owner as well as myself kept it garaged, and didn't smoke or allow pets. The paint is original and for it's age is amazing! clear coat is flaking on two doors that's it. I bought this 60 last summer, and I have spent a lot of time and resources getting it to where it is now. I have receipts for most of the work due to me not being very mechanical. I have since hooked up with a landcruiser club and have learned a lot. I will list with what I have done if it was a mechanic or if it was me and my fellow cruiser heads. mechanically this thing runs like a top, very smooth idle 650rpm/ac idle 900. when cold 4 or 5 pumps on the gas pedal and it cranks right up. When hot it just turns right over. This 60 is desmogged as well. I have kept most parts I have taken off this 60 and it will come with it, plus I have bought lots of other things for it in case things were to break (i'm a worry wort!) Comes with factory skid plate, was taken off for pics.
All this was done in the past 11 months!
- Fountain of youth full tune up kit from cool cruisers (mechanic)
- Toyota Land Cruiser FJ60 Champion 3 Row Aluminum Radiator - comes with old one and it didn't leak (me)
- All 3 belts replaced with new belts (mechanic)
- Troll hole Carb - comes with original carb it worked but wanted the THC for better performance (mechanic)
- New Alternator - comes with old one but it needs work (mechanic)
- New hood bump stops and new hood stand retainer clip (me)
- All new vacuum lines (me)
- Fixed the rear window washer hose issue (me)
- 3 all new window wiper blades along with all new wiper blade Toyota oem arm covers (me)
- New radio antenna (me)
- New License plate lamp kit - comes with old one (me)
- All rear tail light bulbs replaced (me)
- Bumpers were taken off and back of bumpers were undercoated to prevent rust (me)
- Old Man Emu/ Man-A-Fre FJ60 4-inch Suspension w/ Shackle Reversal Kit (mechanic)
- Wrangler dura-trac 33 inch tires (tire shop)
- All new exhaust- pipe and muffler (mechanic)
- Front brakes- new rotors and pads (mechanic)
- Rear brakes- brake cylinder replaced and drums re surfaced. (mechanic)
- front drive shaft lengthened- as well as front and back drive shaft balanced (mechanic)
- New charcoal canister - comes with old one (me)
- New fuel oem gas cap - comes with old one (me)
- New oem front wheel well rubber skirt kits (me)
- New fj62 mirrors - comes with original fj60 mirrors as well (me)
- New oem check valves for front head light washers - so they actually work! comes with old ones (me)
- New front grill, OEM Toyota emblem, and headlight grills - comes with originals (me)
- New OEM side markers
- Had diffs fluid changed, Transfer case and transmission flushed and serviced (mechanic)
- New OEM fuel pump
- New JT Outfitters Hydraulic Clutch Conversion. That's the master, the slave, and stainless steal hose makes the clutch very crisp! great upgrade (mechanic)
- New Autocraft Gold Battery
- I just sourced a un damaged air cleaner hose, will be swapping that out soon as it arrives. (me)
- Has the original jack and jack kit
- Sor High density seat foam and new upholstery - seat frames were treated and painted - comes with original upholstery and foam(only driver seat side is ripped). (me)
- Hexagon floor mats and some custom window sun-visor
- All interior bulbs have been replaced with LEDS - instrument cluster- hvac- dome lights (me)
- New pioneer head unit and Polk Audio speakers - Wasn't oem tape deck in it so that's why I replaced it (stereo shop)
- New OEM gas, brake, and clutch pedals
- AC was serviced and Charged the 1st month I got it - still blows ice cold! (mechanic)
The Good
Everything works on this 60 as it should. I have spent much time making sure of this, there is no issues! The head light washer squirts, the carb fan cuts on for 15 mins after vehicle is shut off, 4wd works perfectly, the locking hubs turn smooth as butter. interior is perfect except for carpet has some traffic wear but nothing terrible. Headliner is perfect with no tears or droop. The clutch is crisp and shifts with ease! The 2F is very peppy for a 2F. I have driven a 40 with a 2f and it felt very sluggish in comparison.
The Bad
Very slight front timing cover leak - add half a quart maybe every 1500-2000 miles.
two passenger doors have clear coat flaked off - These pictures were with no spray on detailer or wax, I've been slowly working the flaking down the doors with pressure washer. When waxed you can't even tell the clear coat it gone. Driver side sun visor likes to flop in your face sometimes.
The Other
When I said im a worry wort and buy extra stuff I meant it! I have a whole other set of ac vents two of which are close-able. I was going to eventually change the two middles with the close-able ones, so all vents could be shut off. I have a whole extra set of seat belts. I have a few windows cranks, headrest post, clips for the grills, extra driver side seat track, extra led bulbs plus original bulbs, and even a full knuckle rebuild kit ( doesn't need it, but one of the most common issues with these so I went ahead and bought it). Also comes with a ton of old school manuals, original window sticker, and some interior sticker decals (in case the ones on the glove box ever began to flake) There is also other things im forgetting for sure that will be included.
PICS: LINK BELOW
FJ60
I'm not wanting to sell this as much as trade it. I don't need to sell it or trade it for that matter. Cash price would be around 23k.
I'm also aware I posted this in the 40 section. with the amount of response I got I wanted to make a cleaner organized post and figured it wouldn't hurt to post in the 60's classifieds.
As for 40's I currently have a offer and hoping we work it out, but if not im open to anything. I like a all original, to a sweet resto mod. I would like hard top and hard doors as a preference, but if the 40 is cool enough I could look past it. If you don't feel that your cruiser is close to the cash price by plus or minus 5 grand you might have to add with your offer. I would prefer to not have to add.
- New OEM fuel pump
The Good
The Bad
The Other
PICS: LINK BELOW
FJ60
