My fj45 project
Adelaide
Hi all. Just bought my first fj45 and joined the forums recently. Was purchased off of a rural property here in south australia. In very rusty and rough condition. It is now running thanks to some help from the forums here.
Thought i would post some pics as a starting point. Ive never restored anything. Period. I have limited mechanical knowledge so its a massive project fo me. I dont even know where to start!
Heres some pictures anyway from the day i got it
I've decided to start small. On a panel such as this one. I have decent welding skills. No bead roller or metal forming tools.
Any suggestions on where to begin? Ideally id try and limit the use of bog where possible
I’d throw that in a bucket of evaporust and after a good soak clean it off, spray some fluid film on the bare spots (that had rust) and put it back on. On the body where there‘s rust bubbles I’d take off the bubbly paint and brush on rust converter. Same with the floor. Unless your going for a full blown resto and not keeping it a user rig.
Im undecided at this point how far to go. It was always intended to be a restoration. Whether i do a ground up resto is another question, or if i just do cosmetic and safety issues so it looks and functions nicely.
I think its more a case of my abilities, how easy i find it to repair sections as to how far i go with the whole project.
Will source some rust converter. Also looking at mollasses as ive heard that works to remove rust gently too
I believe its a 1975. That was my next thing to figure out. The compliance plate doesnt state engine number or build date/year. I was wanting to check whether it has the original engine or not.
Im guessing the year is 1975 using the tables from specter offroad. Built roughly around July/August
Check the Data plate above your heater blower motor. It should have the information you’re looking for.
Okay yep that one only has model. Engine type. Frame no. Colour. Trans and plant/gvm.
Ill do some more digging see what i can come up with
