My Favorite Color Is Mustard - A Full Restoration
Watch out. Purists beware! What you are about to see is neither stock, ideal, or completely removable. I had to make some compromises on the roll bar. There just aren't any easy places to tie to the frame. I tip my hat to anyone that has isolated an internal cage from the body on one of these. Even when I brought in some local experts, no easy answer came to us.
The solution isn't perfect, but I very much like the way the final product turned out.
We started by locating and cleaning space for some .25 inch pads.
Next::Bumpers. (I had a hard drive crash about this time, and I lost all of the mock up pictures as well as the early construction ones.) The pics I have are closer to the end of the process.
I know it's a little heavy. It's a little obnoxious.
The horizontal members are 2X6 in the front and 2X4 in the rear. The vertical members in the front are solid .5 inch water-jetted steel.
New seat covers from SOR, installed with new foam. Yes, I put the plastic pullover covers on top of the new covers shown here. I'm not the only OCD person here. The rest of you know who you are. I've read your posts.
My bench seats didn't have headrest tubes, so I had some super hard 2 inch kayak brace foam cut and covered in gray vinyl to make headrests. It looks a little dorky, but you feel a lot better driving at night or in the rain when you have it behind your head.
When the top and back are off, one snap and some velcro lets you pull them.
The H55. The five speed. Every FJ40 driver dreams of it whenever driving faster than 50mph.
I called Cruiser Dan and bought a brand new one.
Gulp.
Let me show you photos of what happens when the shop you choose doesn't have experience in making the swap. There are plenty of posts here on the topic. Let me show you in pictures exactly what can happen.
First. This is your 4 speed gearbox.
As I said. This is the result when your shop doesn't have experience in doing the swap. That doesn't mean that my local shop wasn't good. Far from it. Since my old gearbox was perfectly fine, they were able to press the gears off each gearbox's input shaft, re-press the gears onto the new shafts and reinstall everything.
I would have been pooping my pants, but they pulled it off. I've been driving now for over 2 years and it still shifts like butter. (As much as an HJ-47 is going to be butter-like anyway.)
There was no need to do a 60 series axle conversion to get the rear parking brake feature.
Everything does move back. When installing the H55, you will have to do something with the gap on the gearbox cover. This plastic is temporary until new sheet metal is welded into place.
In my case, the transfer case actuator still fit in the stock opening. 4H and 4L are right at the edge, but they work fine.
