My Cheap Puma Mount
TYM4FUN
USA
While waiting for someone to fab up Puma mounts again, I decided to tackle it a more cost affective way. Making my fridge slide gave me some inspiration to use what materials I had laying around for the mount. It utilizes the factory seat bracket, 3/4" ply, modified electrical conduit, and some hardware.
Cardboard template.
Electrical conduit squeezed, drilled, bent and painted.
Painted Rust-Oleum Bronze and mounted.
U-bolts and new bracket in place.
Puma finally at Home!!!!!!:bounce:
Trimmed the original rubber feet for the spacers.
This was needed for the tank to clear the U-bolts. Used fender washers on opposite side.
Cardboard template.
:bounce:
So...you are going to bolt the PUMA to the board?:)
Trimmed the original rubber feet for the spacers. This was needed for the tank to clear the U-bolts. Used fender washers on opposite side.
*I tried uploading pics earlier, but the site is not letting me at the moment.
Love it! I need to do this right away!
What size is that conduit and how long is the piece you cut?
1/2" conduit, I think the length is 8". The length can very depending on where on the platform you attach it. In the pic you can see the tube is not centered from front to back.
If I made another one, I would probably shorten the tube and have the mounting point moved rearward to center it. This would make it a bit stronger, but I don't see any problems leaving the original prototype the way it is...
Looks bigger in the pictures.
Great solution and nice fit. There are plenty of people looking for a mount like this, you could probably sell several!
P
Perfect. I have some of that lying around and I'm going to try to mount mine on the passenger side where my power is. The Puma isn't as heavy as my stored 3rd seat. Should support it.
Me like:clap:
I was going to be tackling this when it warms up a bit...now I don't have to put too much thought into it (he said, lazily), thanks!
Here is what I made using the seat bracket. I am going to add another brace in the back. Spent $30 in steel and bolts from Lowe's.
Looks good. If I could weld, I would fab something up without the seat bracket. Just incase I needed to throw the seat in again.
I need to buy a welder and practice/take classes.:bang:
Lol, yup. I bugged you Arizona guys to make them. Bought one from your first batch a long time ago....thanks!
